I upgraded from my broke 2000 f350 to a 2020 f350 and so far love it. But to finish it out I have to reinstall the factory prep on it. My problem is I don’t have the outer brackets, I assume the inner brackets are there and I have the crossmember. I can source regular bolts easy enough as well as the light plug wiring but does anyone have a source for the outer frame brackets? Really hoping to avoid buying the whole package. Other than a junk yard any leads?
Those parts alone are unobtainium from Ford. Your only source are used. By the time you source all the parts you will probably be at around the same cost as the kit.
