Fuel System Issue
Old Jun 27, 2023 | 02:07 AM
mitch1227's Avatar
mitch1227
4wd Low
Fuel System Issue
Hi, I have a 1990 F150 standard cab with a 4.9. I was running my truck the other day and the rear tank started overflowing at the cap. Both tanks have new fuel pumps and lines that are two years old. I ended removing the rear tank because I wanted to replace it anyway and while I was running the truck with the front take fuel was squirting out of one of the lines that went to the rear tank. I capped it off and am just running the front tank until I buy a new rear one. My gas gauge also stopped working. Is there a reason why my truck is sending fuel from the front tank to the rear tank while I’m running the front tank? Do both tanks have to be connected for the gauge to work? Thanks for the help.
Old Jun 27, 2023 | 06:09 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I’d say the check valve in both pumps went bad. You don’t have it capped off correctly? No, each fuel delivery module has its own fuel sending unit. What is it doing? Is it reading empty, full or is it stuck somewhere in between?
Old Jun 27, 2023 | 06:27 AM
rla2005's Avatar
rla2005
Yes, the very common crossflow issue is caused by a bad check or shuttle valve in the rear fuel delivery module (for your scenario). Aftermarket versions tend to have a short life.
No, both tanks do not need to be connected to make the gauge work.
Fuel tank selector diagram for your 1990 model year gas engine truck.
Old Jun 27, 2023 | 08:11 AM
manicmechanic007's Avatar
manicmechanic007
Simply find and add one-way
There are used ones at the junkyard that are still good
valves to both tanks
Old Jun 27, 2023 | 12:19 PM
mitch1227's Avatar
mitch1227
4wd Low
It will read around a quarter tank sometimes and past full at other times, but mostly stays at a quarter. Thanks for your response.
Old Jun 27, 2023 | 01:06 PM
My4Fordtrucks
I am thinking the rear pump check valve went bad. You removed the pump but didn’t plug the lines good enough for the amount of pressure. The sending unit in the front pump is now failing but don’t take my word for it. Rla is much more knowledgeable about this problem than I am.
Old Jun 27, 2023 | 11:43 PM
Ronniewhite's Avatar
Ronniewhite
Bad check valve in rear pump. I bought a new cheap pump from rockauto. It was a ultra pro or ultra power something like that and it was bad right out of the box. I read a couple weeks ago on hear that same pump and same thing happened to another guy. I put a Delphi pumps in. Hopefully I won't have to worry about them again. The cheap pumps would probably be ok if you only had one tank but there no good with dual tanks.
Old Jun 27, 2023 | 11:56 PM
mitch1227's Avatar
mitch1227
4wd Low
Don’t think I’m dumb, but what is that? I’ve been working on my truck for awhile now and research before I do anything, but I don’t recognize that part.
Old Jun 28, 2023 | 05:56 AM
My4Fordtrucks
Those are in-line check valves. Instead of going through the hassle of replacing the faulty check valves on the FDM , Ford had a TSB where those were installed between the lines and the FDM.
Old Jun 28, 2023 | 01:11 PM
mitch1227's Avatar
mitch1227
4wd Low
Thank you. Where do I place the valve as far as location on the line?
Old Jun 28, 2023 | 02:55 PM
My4Fordtrucks
Already stated where they go.
Old Jun 30, 2023 | 01:41 PM
mitch1227's Avatar
mitch1227
4wd Low
Will this work?
Old Jun 30, 2023 | 08:52 PM
manicmechanic007
The fuel check valves issue was a recall
2 recalls in fact and affects 90-93 full size trucks
93S68 was the second one (I believe) where the fuel pressure regulator was also replaced.
Old Jul 1, 2023 | 01:45 AM
mitch1227's Avatar
mitch1227
4wd Low
I’m assuming it’s a little too late to get them fixed at the dealership. LOL.
Old Jul 1, 2023 | 07:02 AM
Thejackalope's Avatar
Thejackalope
If it was a TSB, yes. A recall is forever until it is fixed. My 96 had the cruise control recall done in 2017 or 2018.
Apr 18, 2023 09:10 AM
kc5wxc
Aug 23, 2012 08:16 AM
Penrider
May 10, 2010 03:02 PM
ltatkinson
Apr 9, 2009 10:35 AM
tralfamadorian
Mar 15, 2009 02:49 PM
