Modular V10 (6.8l)
2007 PCV Valve
Old Jun 25, 2023 | 06:39 PM
snb13's Avatar
snb13
2007 PCV Valve
I've seen what appears to be conflicting info. So, on a 2007, where is the PCV valve located and what is the proper part number?
Thanks!
Old Jun 28, 2023 | 06:05 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Rockauto shows it as a Fram FV403, and it is located approximately over the number 4 cylinder.
Old Jun 28, 2023 | 06:25 AM
projectSHO89's Avatar
projectSHO89
If equipped with PCV, you should be able to follow the larger hose from the intake to the valve cover.
Old Sep 4, 2023 | 04:58 PM
blue66tang95f150's Avatar
blue66tang95f150
Did you figure anything out on this. I have a 2005 and for some reason everything is different on the internet then my truck. My truck has a line coming out of the passenger side valve cover just behind the oil fill toward the front of the engine that plugs into the intake hose just in front of the throttle body. On the drivers side there is another line coming out of the valve cover and going back to behind the intake. I cant quite see what it plugs into, however what ever it plugs into looks like it has water running through it. My truck is throwing p0171 and p0174 and I cant figure it out. the only thing I can think of is that my pcv system is not working properly and it is causing a lean issue.
Old Oct 30, 2023 | 04:08 PM
snb13's Avatar
snb13
I have the internal PCV system, which I'm told is working fine. Unfortunate as my truck is just drinking the oil.
Old Nov 1, 2023 | 03:25 PM
super 6.8's Avatar
super 6.8
Are all 2007 V10's using an internal PCV valve where you have to swap the valve cover to replace it?
Or can you simply swap the valve in the top of the valve cover?
R1trevor
Apr 15, 2021 07:25 AM
Homerunking2394
6.2L V8
Nov 28, 2017 09:27 AM
spartan
Modular V10 (6.8l)
Mar 23, 2008 05:49 PM
