A/C thru defrost only.
Old Jun 24, 2023 | 12:12 PM
majchap's Avatar
majchap
1st Gear
I’ve read up on this common issue however still having problems.
Can someone tell me where this vacuum line connects? I know where it doesn’t connect so if someone could send me a picture of its connection point I would be grateful. Thanks.
Old Jun 24, 2023 | 06:01 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. Thank you using the introduction section for your first post. However, you will not get many responses here. First, you ask a very general question with a very generic picture attached. Please review the various forums, (click on the Forums button on the top left of your screen), then choose the correct truck to which your inquiry applies. Is it a 150, 250, bigger, small chassis? Adding the year and engine size of the vehicle will help too. Often these trucks are so very similar, it is hard to determine a particular model, from such a small portion image.
Don't forget to stop by your state chapter and join them too. Sometimes, help is right around the corner.
Old Jun 25, 2023 | 06:03 PM
salar's Avatar
salar
Banned
Welcome I hope you get the main issue
Old Jun 25, 2023 | 11:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Hard to tell without knowing the year, make, model, and engine of the vehicle.
Welcome aboard!
alloro
Nov 8, 2021 10:28 AM
BigMattXXL
Apr 9, 2003 10:51 PM
