Help
Old Jun 22, 2023 | 04:25 PM
jordon s's Avatar
jordon s
3rd Gear
Help
I recently bought a 1985 bronco ii xlt and driving it home it cut out and hasn’t started again since. I’m honestly stumped on what to do next it has fuel running into the carburetor. It has spark I changed all the spark plugs today it did make it almost start but not quite. Only thing else I can think of is a compression issue but I want to see what other people think first
Old Jun 22, 2023 | 04:39 PM
Franklin2's Avatar
Franklin2
When you try to start it, look down the carb throat afterward. If you see fuel dripping into the engine, the carb is flooding the engine and drowning the sparkplugs. This is my guess since new plugs made it almost start. If you see fuel dripping down the carb throat, it must have a piece of dirt stuck in the carb needle.
Old Jun 22, 2023 | 04:43 PM
jordon s's Avatar
jordon s
3rd Gear
I wouldn’t say it’s dripping it just sprays when I give it some throttle
Old Jun 22, 2023 | 04:51 PM
Franklin2's Avatar
Franklin2
Don't touch the throttle, but crank it over a little bit. No liquid fuel visible down the carb throat?
Old Jun 22, 2023 | 04:52 PM
Franklin2's Avatar
Franklin2
You could also pull a sparkplug back out and see if it is wet with fuel.
evan_nugget
16
Oct 14, 2022 09:42 AM
Rockstar Welder
1978 - 1996 Big Bronco
May 28, 2015 10:33 PM
North_of_60_F250
Jan 18, 2009 02:48 PM
Jrock909
Nov 14, 2004 10:28 PM
Pronounced"FORD"
Feb 27, 2004 10:39 AM
