Sponsored by: Auxito
Hits a wall accelerating
Old Jun 20, 2023 | 08:29 PM
Ba Mustang's Avatar
Ba Mustang
Trailering
I have an issue where my 98 4.6 will hit a wall when trying to accelerate. It happens around 2500-3500 rpm no matter what gear I’m in. It idles fine and cruises down the road just fine. When it hits the wall I can let off the gas, give it throttle again and I may gain 500 rpms before it hits the wall again. I previously had issues with misfires and lean codes but those have since gone away. I tried cleaning the egr valve with carb cleaner but that hasn’t changed anything. The engine also revs freely in park so only happens when under a load.
These are the parts I’ve replaced so far to deal with the misfire and lean codes I had previously. I’ve put 30+ miles in it since replacing these and no codes have shown back up. One known issue is the speedometer is off due to larger tires, I’m currently waiting on the replacement speedo gear.
Spark plugs
Fuel filter
Fuel pump
Fuel pressure regulator
Upstream O2 sensors
is a video I recorded of it going through first and second. About half way through I have my foot to the floor and hold it the rest of the time.
Old Jun 21, 2023 | 04:16 AM
Jon Freeman's Avatar
Jon Freeman
Maybe transmission problems ?
Old Jun 21, 2023 | 05:43 AM
Ba Mustang's Avatar
Ba Mustang
Trailering
I’m starting to think that is the problem. Fluid looked good though, may have been slightly overfilled. I forgot to try it but I need to go back and manually shift the transmission to see if it still does it.
Old Jun 21, 2023 | 12:04 PM
70f100longbed's Avatar
70f100longbed
Cats are probably restricted. You could try loosening the pipes at the manifold and see if it still hits the wall. Highly doubt its a trans problem. I've also seen the plastic cone come off the air filter and block the flow when it was under a load.
Old Jun 21, 2023 | 12:21 PM
Ba Mustang's Avatar
Ba Mustang
Trailering
My coworker and I were talking about a good way to test out the cats, I'll have to give that a try. I may go ahead and remove the filter during a test drive to also eliminate that possibility.
Old Jun 21, 2023 | 07:21 PM
97F250guy's Avatar
97F250guy
4th Gear
I am thinking the same thing, if the transmission was slipping that badly it should stink of burned clutch material.
Old Jun 22, 2023 | 10:17 AM
Hit Man X's Avatar
Hit Man X
Cats or fuel delivery.
Fuel filter installed correctly? I have pulled them off backwards before. May want to get a gauge and run it to the cabin to check pressure under heavy load.
Maybe with a scan tool you could see O2 data under load too.
For cats, I would just remove the front O2s and go for quick spin. Truck been sitting? Maybe some critter built a nest in the tailpipe. Happened on my 4.9 truck I pulled from junkyard...big cloud of acorns came out of it.
Old Jun 22, 2023 | 11:42 AM
Jon Freeman
That doesn't seem to coincide with the problem being plugged cats or fuel system issues.
Jcon11
6.2L V8
Dec 12, 2023 07:40 AM
Marty1965
1997 - 2003 F150
Sep 25, 2018 01:16 AM
Markrichter
Jan 4, 2016 11:30 AM
pounder90
1997 - 2003 F150
37
Apr 16, 2014 07:12 PM
richmon
Nov 23, 2003 06:14 PM
