Butchering an E4OD
I did get a good used pump and went through it. Knowing that Ford had an oil delivery issue, I elected to open up the intake ports on the F5 casting and smoothed out the path before the pump gears take over.
Then I replaced the pump/converter bushing and buttoned things up.
At this point, I got the low/reverse piston in, clutches, and rear 6 planet iron gearset in. I did weld the 4R100 steel basket a little. Pretty simple, just a bunch of small welds. Looking at other sites, I guess this helps prevent the basket from breaking away from the sprag holder. One of the benefits of using the 4R100 parts is that you get one more roller so I would assume, a little more holding power.
I was able to tig weld the two plates on the coast clutch and did a final check. Should be fine. If I had the right lathe, I would have used the stock plate and just cut the teeth down to accept the snap ring. Oh well, I cannot see me buying a larger lathe.
I installed the Tugger kit along with the Zip Kit. Some of the modifications overlap and that is a fear of mine. Both work fine, but do they play together nicely? I drilled .093 holes [2 & 4] and a .073 [3] in the Tugger calibration plate. Shift firmness is a big concern with me. I'm towing, so a firm shift is ok, but harsh is not. I believe with the extra clutches, I can get a strong shift without being harsh. I know I will have to tune these shifts to get it to my liking and I am not looking forward to that. Something about draining the fluid, having transmission fluid dripping on you while dropping the valve body does not sound appealing.
Not a lot of progress with the transmission this weekend. Not because I did not put time into it, it's just there was a lot of messing around with stuff.
I have found that you cannot put in 6 clutches in the Forward drum. Well, actually it can, but the ring gear in the forward planet does not have long enough cutouts to accept 6 discs. The top clutch disc will not allow the ring gear to fit all the way down. I tried every possible combination and the stack is too thick. I believe I could have trimmed the bevel plate a bit thinner and it would have fit, but my lathe is too small. I ended up with only 5 discs. Still, better than what I had and now you know why it will not hold 6. If you pressure check the clutch, with 6 discs, the ring gear moved. Maybe a mm or two, but anything is not good.
Teeth too short to accept 6 discs.
The transmission that is in my truck now, has a large aluminum pan and I would not buy one without a drain plug, so it has one of those too. Like all of them, it holds more fluid and does use the newer pan gasket. I absolutely hate the way Ford routed the transmission dipstick, so one of the mods is to install one from a van. I hope it works and put the stick in a place that I can use it. The other thing in my truck is a larger cooler. I don't see me putting a larger one in it. The fluid temp is ok [I got a temp gauge]. I do plan on getting larger cooler lines. Just not this time around.
As for fluid, as a shop owner, I can get stuff wholesale. I have not looked at fluid, but I am a synthetic believer. There are a few places I would not shop at, O'Really's is one of them. I am not a fan of house brand products. I know, they can be as good as the name brand stuff, but like a totaled/rebuilt title, it's not for me. I'm at the time in my life where I have money, but too damn cheap for having others do work that I can do myself. If I could make oil, I probably would. I will talk to my supplier and he will give me his best advice, at a good price too.
The converter I have, was built by a shop I deal with. Mercedes converters shudder a lot so they rebuild the ones I give them. Not bad, a 6-8 hour turn over. The one they built for me is suppose to be good, not $2k good, but good enough for what I want. One thing I have found, when you have a good relationship with your suppliers/vendors, they usually do a bit better job for you and save you a few dollars too. I forgot to ask for a drain plug in the converter. Still debating on doing that myself. I like drain plugs. Especially with transmissions.
When it comes to fluid, yes, I agree. If the specs say Mercon V, then it's all pretty much the same. There is something in the back of my mind, having a name brand makes me feel better.
I get what you're saying about the name brand thing. About 20 years ago a friend of mine owned a Napa store. He had an S10 truck that he drag raced. It ran 7.90's at 3200lbs with a blown small block Chevy that he abused and turned over 10,000 rpm. He used the Napa oil. I think their oil is Valvoline.
I guess it could have stripped the teeth off of the coast clutch drum OD and or burned up the overdrive clutch. The problem should be obvious when you take out the front pump.
When mine failed the first time, I recall the shop saying the front pump failed. I would agree with that since I heard a loud whining before it just stopped moving.
BTW, welcome new member.
What new problems have I run into? The intermediate clutch has 4 discs. I needed to get the extra clearance to get those to fix. I ended up making a thinner pressure plate. I did get a .326" plate, but a .280ish is what I needed to get the right clearance. I wanted to make certain I used the thicker metal plate on the piston side but if I did not, I could have had a thicker pressure plate. There comes a point where the pressure plate is too thin and will not perform the task at hand. I do not know what that is, but I guess I will find out. It took some time to find out what works and I am glad I checked it. If I did not, I certainly would have had issues. What clued me in was that I had difficulties getting the snap ring in the intermediate/OD piston carrier.
I did not want to go with thinner than stock metal plates on any of my clutch packs, but I did ended up going with the thinner Alto clutch pack for the OD clutch.
I'm going to drill the converter for the plug today, wish me luck.
The core transmission was missing the shift shaft and the used one I got several months ago is too short. One of the goals was to not take apart the transmission in the truck. That goal was not met.
I swapped the transmission and took care of a few things while the truck was in the air [yes, a rack is something everyone should have]. I replaced the stock rear differential cover with a Banks unit. I installed a 4.10 gearset [stock was 3.55] a few months ago. I blew out the cooler circuit to make certain there was nothing nasty in it. Since there was nothing wrong with the original transmission, only nice clean fluid came out. After the installation was complete, 18 quarts of Motorcraft synthetic Mercon V was added.
I backed it out of the shop, yes, it did move, confirmed my wife had her phone and a large dose of patience if I called. Couple stumbles during shifts, but that is common with all the circuits having air in them. After a few seconds of that, the transmission did shift in every gear. 1-2 and 2-3 shift are fine. 3-4 is a bit harsh. I was hoping I would not have to go back into it and I may have to so I can dial things in. Reverse is a bit. More than I would like, but since there is no accumulator, there is little I can do about it. I may want to reduce the feed hole to the low/reverse clutch at the back of the transmission, but I really do not feel like dropping the complete valve body to do that. It's the ***** I really do not want to screw with.
I have a Tweecer so there are a few things I can do before I go back into the transmission. Too late to see what calibration I have in the EEC-IV, but it is possible that the idle RPM can be dropped a 50 rpms. That would certainly help with reverse.
Looking at the calibration now, Ford really puts a lot of TV pressure on the 3-4 shift, so there is something I can do electronically with that. The other thing I do not like is that when the shift goes from 2-3, the converter engages at the same time. The RPM drop is substantial and I plan on delaying the converter lock up so it feels more like an additional shift.
Like all modifications, it's the tuning that makes it all work. That tuning takes a lot of time so it feels right in all situations. Time is something I do not have a lot of. At this time, it shifts, which is a good thing. When/if I can get this thing dialed in, I will be happy. Playing with software is a lot less messy and takes a lot less time. I will be heading that way first. If I cannot get the 3-4 shift to my liking, I guess I will be putting the stock accumulator springs in and/or reduce the .093 hole in the calibration plate.
I hope that the software makes a difference and should know shortly.
I have both strictly stock one each 4R70W & 4R75E where only the 4R70W has the factory drain feature. The years after 2000 in the E-Series eliminated this feature but it doesn't seem to affect anything when using Mark K's full fluid exchange operation.
Interesting thread BTW--well above my head but still fascinating---thanks for sharing your process!
