power lock tool box
Old Jun 12, 2023 | 05:05 PM
st8yd's Avatar
st8yd
power lock tool box
My tool box works well for me, but the locks on it both sides have to be locked individually.
So I was thinking about how nice it would be if they were power locks that activated with the door locks like the tailgate does.
Has anyone done this or is it even possible to tie an accessory circuit into the door locks?
I tried a search but didn't get anything.
Old Jun 12, 2023 | 07:24 PM
GpGuy84's Avatar
GpGuy84
There was a thread on this a while back. I don't remember what the final result was but I think that another member suggested doing a separate lock/remote for the box.
Old Jun 13, 2023 | 08:26 PM
st8yd's Avatar
st8yd
Thanks, but would much prefer it to be all one.
Old Jun 14, 2023 | 11:58 AM
birdnst's Avatar
birdnst
Tool box locks
I have a 2013 f150 KR, I had my local leonard buildings shop install a leer hard cover.
When they did they tapped into a wire under drivers door seal and ran a wire back to cover lock and it operates with my key fob.
This may help.
Old Jun 19, 2023 | 05:34 AM
bdemay's Avatar
bdemay
I am not sure what toolbox you have, but I have the American Work Truck cover and I did this. Assuming you have power actuators in the toolbox, you can connect them to the power lock wires under the passenger side sile plate cover. There is another post if you search for it from a guy who did it and based on this description, and a little messaging back and forth I was able to figure it out also. There is another post showing the pass through wires that go through the firewall from behind the passenger side kickplate, to under the relay terminal box for the up-fitter switches in the engine bay. I used a heat GUN like suggested in that post to remove the sheathing binding the wires. It worked like a champ. You can use two of these wires, or you could drill your own hole and snake a wire in yourself. Your choice. It is great having the tool box lock and unlock with the remote. BTW, I have a 2022, F350 Dually Platinum.
Old Jun 19, 2023 | 05:39 AM
bdemay's Avatar
bdemay
Nickbartels is the name of the guy whose post I read and the post is titled “
2022 F350 Door Lock Wire Colors”
Old Jun 22, 2023 | 06:56 PM
st8yd's Avatar
st8yd
Thanks, I have the Buyers 27" box. There is not any electric locks on it. But I was sure that could be figured out if the electric could be tied in to the existing locks.
lxg44
Sep 21, 2017 10:55 AM
yargnitram
Jul 19, 2011 02:59 PM
bigfishford
1997 - 2003 F150
Sep 25, 2006 04:42 PM
wantobenav
Aftermarket Products
Jun 29, 2005 10:49 AM
jamesbell
Oct 13, 2003 07:53 PM
