Engine ID
Old Jun 6, 2023 | 09:34 AM
Tom's 77 F250's Avatar
Tom's 77 F250
Trailering
Engine ID
Hey guys, I've got this 78 f250 4x4 super cab and am curious if it's been engine swapped. The vin runs that it would have a 400 but I thought the 351's and 400s all came with 2 barrels? This appears to be a factory 4 barrel intake. Would that give this a good chance of being a 460? Pictures kinda suck.
Old Jun 6, 2023 | 09:39 AM
jflem's Avatar
jflem
Looks like a 460 to me. Not the original engine in that truck I don't think.
Old Jun 6, 2023 | 09:45 AM
Tom's 77 F250
Trailering
This truck also has a 4 speed with a married tcase and not divorced like my 77's with a 351.
Old Jun 6, 2023 | 10:05 AM
Tom's 77 F250
Trailering
Here's the block casting number D1VE-6015-A2B
Old Jun 6, 2023 | 10:09 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Married transfer case for 1978 is normal.
That is definitely a 385 series engine (429 or 460).
Old Jun 6, 2023 | 10:12 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Also, is that a square bore Edelbrock/Weber /Carter carburetor on the spread-bore intake? Looks like a good place for vacuum leaks to me.
Old Jun 6, 2023 | 10:36 AM
tbear853's Avatar
tbear853
7 valve cover bolts, 3 along top, 4 along the bottom, none at top corners = 429 or 460.
The 351M and 400 have 8 valve cover bolts, 4 along top, 4 along bottom.
Spread bore intake, Carter Edelbrock like carb, don't believe it would have let throttle shaft turn much.
Old Jun 6, 2023 | 01:06 PM
Tom's 77 F250
Trailering
Are there any numbers on the block that would determine between a 429 or 460?
Old Jun 6, 2023 | 03:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No.
Block casting number prefixes: C8VE - C9VE - D0VE = Internal Balance = 1968/70 429 & 460.
Block casting numbers:
D1VE-6015-AB or A1B or A2B = Internal Balance = 1971/74 429 - 1971/78 & some 1979 460.
D9TE-6015-AB = External Balance, has a weighted crank spacer = Some 1979 460 - 1980/97 460.
OP's engine has a Saginaw P/S pump. These were used on 1975 and later Econolines, 1972/78 Passenger Cars with Hydro-Boost.
429/460 have 7 valve cover bolts per side // 351C/351M/400 have 8 valve cover bolts per side
429/460: The fuel pump bolts to the drivers side of the timing cover.
351C/351M/400: There is no timing cover per se, just a flat engine cover plate.
The fuel pump bolts to the drivers side of the engine block, its bolt pattern is at 6 & 12 o'clock, the only Ford fuel pumps to use this pattern.
Old Jun 6, 2023 | 05:20 PM
Tom's 77 F250
Trailering
Thanks for all the info! Looks like I'll be measuring the stroke. I'd be stoked if it's a 429.
misterjimmy
Nov 7, 2022 06:04 PM
Casey_Kenneth
43
Jul 22, 2021 10:44 PM
Mannysouza
Jan 19, 2021 10:52 AM
GarnetJax
17
Oct 20, 2015 04:34 PM
cscott952
Mar 11, 2014 10:24 PM
