Not true. You can enable manual regen and the DPF screen and then disable automatic regens. When towing I can easily go for a thousand miles without a regen. Also if the exhaust stroke injection is not causing oil dilution, then deleted trucks should see it too, and they don't.
I'm aware of the manual (operator commanded) functionality. I'm not aware that by using that, the "test" regens are canceled out. The reason why you need a tuner to make a delete functional is because of the automatic "test" regens I speak of. Otherwise, why not just fit a straight pipe where the DPF is - no soot would ever accumulate, and the delta pressure sensors would always show a perfectly clean DPF? The system needs a way to know the sensors are working, and the auto 'test' regens are how it knows.
So you're telling me a deleted truck with a leaky injector won't make oil? How many stock trucks are making oil? I don't think its a major concern for most of the trucks out there.
I don't see fuel dilution as a major issue from exhaust-stroke regens. Think about it - the extra fuel is injected just before the exhaust stroke and the exhaust valves open the instant the injection is done. There is no compression, just air pressure pushing the dead end-gases from combustion and the extra fuel out. The natural easiest path for the extra fuel to go is out the exhaust. Could fuel get past the rings? Sure, but probably minute amounts. The 6.7L Ford has the highest oil capacity of any of the current "Big 3" diesels, and therefore by design can handle the most oil dilution. Possibly this is one reason why the Duramax stands at only 10 quarts, because of the 9th injector design. But I just don't see it as an issue on an engine with good compression in good condition.
Active regens must occur even if your truck pulls 30,000lbs every single time its driven, simply because of a manufacturer-programmed cycle to "prove" the the DPF delta pressure sensors work. Granted, these are shorter than a full normal regen. But even hard-working trucks are going to idle quite a bit, and that's just the way it is. Passive regen never clears everything out.
Also think about what surface that fuel is being sprayed when the piston is at the lower stroke. The cylinder walls, in which I'm sure is washing the lubricating oil that resides in the cross hatches.
In addition the cummins is no longer the gold standard in these HD trucks
From the time the regen fuel sprays to the time the piston pushes it out, there’s hardly time for fuel droplets to sit on the cylinder walls. And the fuel is highly atomized, given the 30,000 psi it sprays out at.
I’d still say Cummins is the gold standard. The B series 6.7 found in the pickups is also found in just about every medium duty you can imagine, from International to the Paccar version in the KWs and Pete’s. As far as the RAM trucks, they need a new transmission but not a new engine.
This is so true, the 68re has been in service longer than the 6R140 was even offered IIRC. Not sure if any significant changes were made on the aisin trans. Personally, the 48re I had in my 04.5 Cummins was comparable to the 4R100 I had in my 02 but definitely behind the 5R110 and Allison of the same time. Dodge always seems to lag a bit behind on the slush boxes.
Just bringing it up because it's part of the conversation but both our local tow companies ordered Ram flat beds 6.7 Cummins trucks and always had Ford's prior... When they couldn't get Fords. Neither of them liked the Rams. My buddy has his Ram 5500 and hates it. Has an F550 on order and waiting... Says the trans doesn't shift as good, likes the Powerstroke better and says a smaller vehicle on the flat bed loads down the springs which never happened to the Ford's... Not looking to start a Cummins versus Powerstroke debate just making a comment.
If fuel is making it into the sump, I can assure you it's making contact with the cylinder walls.
Making the Gold Standard will be a hard sell to convince me.
I’ve had two RAM Cummins trucks, still have one, heavy towing for both, for my business. Both have been great engine wise.
That said, I’m pleased Ford is doing the 9th injector design. I just don’t think the exhaust stroke method causes too many issues, and if it does, the engine wasn’t properly designed for it.
We've tried two 6.7 cummins for our farm/ranch business and the 09 6.7 cummins was a disaster and the '13 cummins had nothing but emissions problems, and both made oil like crazy. They just couldn't handle the many short trips. Having said that our 05 and 07 5.9 cummins serves us well. The exception being the transmissions but that's off topic.
Our school has buses with Cummins diesels and they have been costly to operate with all the emissions problems and turbo failures.
You’ll find problems with any engine, but that doesn’t make them worse than the alternatives. For example, just about every International Durastar / MV chassis that is ordered has a “C” on the fender and not the standard Maxxforce engines.
I really like the Ford 6.7, but not the CP4 pump. We have a local waste management company and the owner loves Ford. Bought a bunch of late model F750 trucks with the 6.7 and unfortunately has seen several engine failures at low mileages. He’s buying Hino and International chassis now. Doesn’t mean the 6.7 is a bad engine, just means there are failures and problems everywhere.
My 2023 F250 XLT has done 2 regens, one at 560 miles and another at 520 miles. Both were done when the DPF was at 90 - 95% and the regens were only 5 to 10 minutes of suburban driving. The DPF showed 0% after each one. I don't have the fancy 12" digital gauges but the small screen does have DPF and DEF %, turbo boost and engine braking as well as oil, coolant, and trans temps. It can be found on the measurements screen, which may not be defaulted from the factory. When on the measurements screen press OK on the steering wheel to scroll through the 3 measurement screens, The DPF and DEF are on the third one. To get to it select "Menu", then "Select Screens" and select the measurements screen. You may need to deselect one of the other screens as the number that can be scrolled is limited.
having very much miss my 21 super duty
i found the NEW PORT on the post air charge cooler. tube ..interesting, maybe a future easy tie in for methanol injection???
Giving the DPF its own dedicated fuel injector to light off regens is only one of the many reasons I would say Ford builds a technically superior truck to Ram at this point. Spraying a bunch of fuel into the back cylinder washes it down and will cook the valves and turbo. Put that downstream of the engine and it’s adds complexity and cost but is a win for guys who want their truck to last.
