2022 f350 bad engine harness replace?
Old Jun 3, 2023 | 01:28 PM
Thecoldnw's Avatar
Thecoldnw
2nd Gear
Hello, new member. Second owner of a 2022 f350 with only 9k miles and the truck wont start now. Checked the bjb (fuse box) and it is all corroded. The lid on the fuse box wasnt properly closed it seems like but either way horrible design by ford to put the fuse box where water runs.
After removing the fuse box it looks like the harness plugs are really corroded aswell.
How hard is it to replace the harness?
dealer says it is backordered so i cant have the truck sitting for a month or more. Found a new second hand harness and thinking about doing the job myself.
Old Jun 3, 2023 | 03:29 PM
Under-Pressure's Avatar
Under-Pressure
It’s a Big job to replace a harness properly & could potentially void your warranty if you tackled that job and ran into problems. Ford’s lack of replacement parts & you without your truck for 30+ days is a recipe for the Lemon Law.
Old Jun 3, 2023 | 05:58 PM
1olddogtwo's Avatar
1olddogtwo
OMG, everything is lemon law nowadays on FTE.
Good luck on it with a used truck.
Old Jun 3, 2023 | 07:43 PM
Under-Pressure
How would you recommend dealing with FORD’s refusal to supply replacement parts? How many days without your truck would you be ok with?
Old Jun 4, 2023 | 05:46 AM
1olddogtwo's Avatar
1olddogtwo
I have a surplus of SD's, I've learned to be patient and I am not a very very patient person.
Just received a Kohler engine that I've been waiting for for 9 months, took almost a year to receive a large vacuum pump for a commercial extraction unit, I currently have 6 large desiccant dehumidifiers on order for 8 months, 4 30ton AC units. Semi trailers etc.
It's just not Ford, it's everything thing.
Isuzu box truck, it been 2 months on a AC compressor. I have 6 Super Duty's sitting on the in order Q.... No timeline.
Old Jun 4, 2023 | 08:17 AM
Just Chilling's Avatar
Just Chilling
Being in the business as an owner I can relate. I know all about it.
It is amazing how fast we are becoming more like the third world countries,
20 years ago I spent some time on the mission field in Haiti. Their was to be a wedding
just before we left and some of the ladies were hoping to go to it.
They were not able to make it to the wedding as the plane was leaving and the wedding had been postponed
as the bride had not gotten her dress finished yet.
Back then I could not understand that scenario, now I can.
Old Jun 4, 2023 | 09:00 AM
Split rims's Avatar
Split rims
Be late on a payment to Ford motor credit and watch how patient they are.
Ford is required to fulfill their legal obligations just like you.
Old Jun 4, 2023 | 03:02 PM
Power_Stroking's Avatar
Power_Stroking
Have the dealer order the proper terminals for those two connectors. A lot of them will be able to be cleaned. The ones that can be solder in new ones. The terminal part numbers are in the wiring diagrams. I do this like once a month at my dealer. You’d never even know I was there.
Old Jun 4, 2023 | 03:07 PM
Power_Stroking
There is a large amount of that engine compartment etc that has to come apart to replace that. I promise you don’t wanna do that for free if you can get it on fords dime 😂.
Old Jun 4, 2023 | 03:25 PM
twobelugas's Avatar
twobelugas
with obedient and well trained customers like you, why should Ford address the parts backlog issue.
If this is how things go for 1 to 2 year old trucks, things don't look good for those of us who typically own Ford trucks long past their warranty period.
Old Jun 4, 2023 | 05:12 PM
Thecoldnw's Avatar
Thecoldnw
2nd Gear
hey so they sell the plugs with therminals separate? Have you ran into this exact problem with the fuse box plugs corroded? I was thinking to just clean the terminals and install the new fuse box but afraid in the long run this will come back as my problem again because i know once those plugs corrode a little, they will always keep corroding
Old Jun 4, 2023 | 05:20 PM
1olddogtwo's Avatar
1olddogtwo
Oh my God the sky is falling
Ah, going on 4 mil miles on our fleet.
I think the 22 year will be the worst Super duty, and maybe the early 23s for problems. With that being said I just picked up a 22 a month ago.
I guess this is what loyal obedient customers do, just take, in the raw.
To me it's numbers all about numbers You are never going to bad a thousand percent every time. The mass number of vehicles, No matter the manufacturer at this point, You're always going to have some that have problems.
It's all about the numbers. That was a manufacturer I would be all about getting new product out the door, what's more important thousands of customers stockholders sales people etc versus a few trucks that will have issues.
The parts will catch up, this is a free country nobody asked you to buy a Ford, nobody's telling you today You have to drive that Ford. You can go across the street to the Chevy dealer, GMC dealer or the Ram dealer or whomever you would like and buy their vehicle.
By the way, I own a 04 E350, just a couple thousand miles short of 400,000, runs like a top. To be honest with you with warranties, I truly care less. And my younger days one of the first things I used to do was pull off the DPF and pretty much delete the warranty.
Thank you
Blindsided bleeding blue Ford owner.
Old Jun 4, 2023 | 05:29 PM
twobelugas's Avatar
twobelugas
Thank you
ford thanks you for your patience while they take the money and throws it at EV side instead.
Old Jun 4, 2023 | 11:07 PM
mwheue's Avatar
mwheue
Might check if there is a tsb for 2022 like the 2020 I am attaching.
File Type: pdf
Old Jun 5, 2023 | 02:56 PM
HorizontalHunter's Avatar
HorizontalHunter
I would do the same but you have to have some basic knowledge and do it right. Solder the connections and shrink wrap them to a,e them water tight.
Bob
