Fuel Filter
Old Jun 2, 2023 | 08:39 PM
BigJake72's Avatar
BigJake72
4th Gear
Fuel Filter
I installed a new water separator and fuel filter on my 2022 F-250 SD. How do I reset the fuel filter reminder? It appears the setting for older model does not work.
Help Please.
Old Jun 2, 2023 | 08:53 PM
4wd6.7L's Avatar
4wd6.7L
Are you sure they have a fuel filter change reminder? 17-19 don't have that and I haven't heard of the 20-22 having that either.
Old Jun 2, 2023 | 09:05 PM
BigJake72's Avatar
BigJake72
4th Gear
Fuel Filter
No, I'm not sure if it can be reset. I do know it has a sensor in the water separator. Therefore, I assume it can be reset.
Old Jun 2, 2023 | 09:07 PM
4wd6.7L's Avatar
4wd6.7L
The sensor is a water in fuel sensor only.
BigJake72's Avatar
BigJake72
4th Gear
Fuel Filter
Old Jun 2, 2023 | 09:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, there is no fuel filter reminder to reset.
Old Jun 2, 2023 | 09:34 PM
chadstickpoindexter's Avatar
chadstickpoindexter
No fuel filter reset on my 22, or any other SD I have seen.
Old Jun 2, 2023 | 09:42 PM
BigJake72's Avatar
BigJake72
4th Gear
Fuel Filter
Thanks, my reason for asking such question is; I had my vehicle serviced (just an oil change) at Ford and they wanted $474.00 to replace the water separator, fuel filter, and cabin filter. I purchased these items from the local auto parts store, and install them for less than $100. I assumed a reset had to be performed as with the oil change reset. Again, thanks.
Old Jun 2, 2023 | 09:54 PM
1olddogtwo's Avatar
1olddogtwo
There is NO reset, ever!
Just oil.
Old Jun 3, 2023 | 07:18 AM
chadstickpoindexter
Yep, only the oil reminder gets reset. On the 22's, the air filter minder is also in the dash settings, but I have no idea what it will indicate when the air filter needs changed, or if it needs to be reset or if it does it on it's own. So far I have changed my air filter out yearly regardless.
Also, unless you need to let the dealership to do your routine maintenance, if you are capable of doing it, I would recommend doing it yourself. Not only will you save a ton of money, but you will also know what was actually done, and what was actually used... there have been stories about dealership's doing some weird and "cost effective" things... plus, they like to "find" things that "needs" to be done too... overall, I (and many others) just don't trust them. I guess if you know them personally and have a good relationship with them, it may be a little different, but routine maintenance on these things are so easy to do. Rotating the tires has been the most time consuming and "difficult" part for me, but only because I don't have a lift and am doing one wheel at a time. Greasing the front u-joints are also easy to do, especially if you do it while rotating the tires.
Old Jun 5, 2023 | 06:37 AM
rufushusky's Avatar
rufushusky
Yikes.... that is spendy!
Old Jun 5, 2023 | 08:27 AM
mcmurm's Avatar
mcmurm
Yea, that's borderline criminal. What is that, $150 in parts and over $300 in labor that will take 45 minutes at a snails pace?
Old Jun 5, 2023 | 05:15 PM
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
Really? My 2015 had it.......can't imagine they would get rid of a feature that reminds people to take it to the shop and give Ford money.....
Old Jun 5, 2023 | 05:19 PM
honda250xtitan's Avatar
honda250xtitan
I mean, mine has it.....itll pop up when you forget to plug the sensor back in lolol
Qwazert
6.2L V8
Oct 26, 2024 09:17 PM
Farmboypowerstroke
Jan 1, 2010 08:58 PM
61 uni
Nov 22, 2008 08:20 AM
Finally
Mar 24, 2005 07:12 PM
