Help Break problems!
Old Jun 2, 2023 | 05:46 PM
6.9_4spd's Avatar
6.9_4spd
I have a 1985 Ford F250 with a 6.9 and I have vacuum but my brakes absolutely suck and my pedal has a hard time returning. I was wondering if anyone knows what my problem is if someone does have an answer I would really appreciate it.
Old Jun 2, 2023 | 07:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
first thing to check is fluid level in master cylinder.
second would be to adjust rear breaks.
if pedal still does not come up after doing both of those, then check pedal return spring.
Old Jun 3, 2023 | 01:37 PM
6.9_4spd's Avatar
6.9_4spd
I did all except for adjusting the rear brakes. What does it take to do that.
Old Jun 3, 2023 | 02:59 PM
airdale94's Avatar
airdale94
They are self adjusting most of the time. You can drive in reverse gear and moderately fast lock up brakes a few times and they should improve. Also you can on the back side of (bacvking plate) they are a couple slots to get a brake spoon in there and turn the adjusting wheel. Sometimes you have to punch the slug out of the slotted area with a punch
pat420swed
22
Nov 2, 2016 07:23 AM
Curt Bates
Jan 27, 2012 01:12 AM
1957F100
20
Jul 14, 2007 11:19 PM
1957F100
Jul 11, 2007 10:47 PM
wobndob
Aerostar
Dec 30, 2004 02:06 PM
