Loses Power at Speed
Old May 28, 2023 | 06:56 AM
jjenco's Avatar
jjenco
6th Gear
Four times in the past 3 months my 2003 Expedition 'Eddie Bauer' edition 5.4L has suddenly lost power while driving and begins coasting. Pressing the accelerator pedal does not respond. If you stop, turn off the engine, and then restart the engine, everything works normally again. Truck has 250,000 miles. Last tune up coils and plugs at 120,000. It sometimes 'chugs' intermittently while driving. Oil change every 3000 miles since New. Thanks for any help.
Old May 28, 2023 | 09:32 AM
alloro's Avatar
alloro
Possibly the ignition switch. Turning the key off and back on allows worn contacts to reconnect.
Old May 28, 2023 | 10:10 AM
aquanaut20's Avatar
aquanaut20
Next time it happens connect a scanner BEFORE resetting key, take note of codes and freeze frame data..
Ughh
Jul 7, 2023 01:04 AM
Hotpocket
Jun 4, 2014 11:46 AM
Bigches
1983 - 2012 Ranger & B-Series
Mar 8, 2008 10:03 AM
kaih
21
May 14, 2005 01:51 AM
