Brake Fluid?
Old May 28, 2023 | 07:25 AM
GAZZILLA's Avatar
GAZZILLA
I like to change all fluids once every 5 years or just get rid of vehicles altogether after 5 years so I don’t have to change them.
That’s one of the reasons I sold my 2017 C7 Corvette after 5 years. The other reason was that’s when all of the warranties expired. It also still had the original battery in it that was going to need to be replaced.
Old May 28, 2023 | 08:33 AM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by redford
Does anyone use speed bleeders?
Speed Bleeder Main Page
I use these on my classic cars, just screw one in as replacement for the bleeder screw, then put a hose on it so the fluid pumps into a clear container like a water bottle. Pump the brakes a few times, top off MC fluid, repeat until clean fluid is seen, put bleeder screw back on.
Looking at that site it shows SB3824 which is 3/8 x 24 but has different lengths anyone know the length? It also appears that the 2016 & 2021 are the same part # but length?
Old May 28, 2023 | 02:56 PM
wheelerfreak's Avatar
wheelerfreak
I have them on my Jeep and Toyota but haven’t installed them on the SD yet since it only has 9k on it. They sure make bleeding the brakes easy.
Old May 28, 2023 | 04:25 PM
aklim's Avatar
aklim
I prefer the flush with motive products. You can get it with different adapters and use it for different cars.
Old May 28, 2023 | 08:52 PM
RidgwaySD's Avatar
RidgwaySD
I have used my Motive Products bleeder for over two decades, great piece of kit even used it to push air bubbles out of the cooling system on my Cayenne Turbo (overheats if you don't) with the right adapter.
Old May 28, 2023 | 11:28 PM
aklim's Avatar
aklim
I set it to about 15 psi and let it push the fluid through. With the reservoir you can't run empty unless you forgot about it.
Old May 28, 2023 | 11:48 PM
HRTKD's Avatar
HRTKD
I have the Speedi-Bleed system. It works well for me. I try to flush brake fluid every three years, but I'm late doing it on the F-350.
Old May 28, 2023 | 11:58 PM
aklim's Avatar
aklim
Might be easier to do it every 2 years so "Odd year, flush. Even year, don't".
Old May 29, 2023 | 02:46 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Brake fluid is not a critical fluid to worry about. Plenty of vehicles out there 10-15-20 years old that have never had a flush done...just normal bleeding during brake jobs. So if you don't flush yours every 2 years, or as long as you don't take your F350 to the race track, you'll be just fine.
I'm in no way saying it's not a bad idea to change the fluid. My truck is 5 years old and hasn't had the braking system touched. It's on the to-do list, but I'll get to it eventually.
Old May 29, 2023 | 09:13 AM
fordman19762003's Avatar
fordman19762003
I have a tendency to go overboard with fluid changes but the brake and power steering fluid I let go. I don't tow much or ride my brakes hard so I don't see the need to change the fluid outside of when the brakes need replaced, which I've never kept a vehicle long enough to wear a set of brakes out.
AZFordLover
Sep 26, 2022 07:16 AM
onug
2015 - 2020 F150
15
May 6, 2016 10:57 PM
Headviking
Aug 7, 2013 12:25 PM
90XLT_Silver_Bullet
Aerostar
Oct 24, 2003 08:50 AM
