Bilstein Shock Questions
Old May 29, 2023 | 02:57 PM
-David-'s Avatar
-David-
I have to ask the question. If the 5100s extend longer than stock shocks and are designed for 2"-2.5" of lift, then would there be concern that the front springs can unseat when in full droop when 5100s are used with stock ride height? It is my understanding that the shocks limit the down travel. At minimum you would have greater articulation assuming the sway bar is not limiting articulation. Also aggravating the issue would be the ride height difference between 17-19 and 20+ and what does 2"-2.5" really mean... on a 17-19 or a 20+?
Old May 29, 2023 | 02:59 PM
4wd6.7L's Avatar
4wd6.7L
Yes, that would be a concern with a shock that has a long enough extended length to allow that, the Bilstein 5100 in question does not.
To further put this in perspective, the FOX 2.0 listed for the 17-23 Super Duty w/0-1.5" lift has an extended length of 22.28", a full inch longer than the 5100 (21.22"). The 5100 gives very little extended travel compared to the stock shocks, and only has approx 5/16" longer extended length than their stock replacement shock, the 4600.
Old Jun 14, 2023 | 12:44 PM
F250Smitty's Avatar
F250Smitty
Probably a silly question, but do the boots on the bilstein 5100's go up or down on the rears?
Old Jun 14, 2023 | 12:48 PM
4wd6.7L's Avatar
4wd6.7L
The shortest 5100's are shaft up, so boot up. Some of the longer lengths may be shaft down.
Old Jun 14, 2023 | 01:05 PM
F250Smitty's Avatar
F250Smitty
Seemed like the boot is close to the frame, thanks for the quick answer!
Old Jun 14, 2023 | 04:15 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Yep, the boots go up on the 5100's. You should be able to read the sticker when installed.
Old Jun 14, 2023 | 06:31 PM
wheelerfreak's Avatar
wheelerfreak
This. Per Bilstein's website the stickers on their shocks should always be right side up and readable when installed.
Old Jun 14, 2023 | 06:35 PM
ShotgunZ71's Avatar
ShotgunZ71
Right on! Only one way for them to be installed, per Bilstein. Thanks for helping the OP, fellas!
Old Jun 15, 2023 | 11:13 AM
F250Smitty's Avatar
F250Smitty
Thanks again everyone!
ChiefGeek
Jun 14, 2023 04:36 PM
dmueller71
Jun 22, 2017 03:32 PM
Criegg
Oct 27, 2015 06:17 PM
ktplotts
Apr 9, 2008 06:37 PM
tangcoral2004
Jan 8, 2005 09:33 PM
