223 inline 6 mounting points
Old May 23, 2023 | 10:17 AM
Turkeytruck's Avatar
Turkeytruck
2nd Gear
Hey everybody new to doing classic cars and a total noobie.
I have a 1955 f100 and I am wondering if all 223 inlines and three on the speed trans bolt to frame or just a certain number of years work for 1955 f100.
I feel like they would be the same, thinking about purchasing one and want to know before I make the purchase.
like I said, total noob here, just starting to learn.
thanks!
Old May 23, 2023 | 04:49 PM
f5fordgirl's Avatar
f5fordgirl
As far as I know, all ford pickups from 53 through 64 mounted the engine, 6 cyl, and V8 by the bellhousing to the crossmember, and a U shaped mount on the engine front, the engines had side mount holes that were used in cars.
Old May 23, 2023 | 11:54 PM
mOROTBREATH's Avatar
mOROTBREATH
^^^He's correct.
Old May 24, 2023 | 07:19 AM
bigwin56f100's Avatar
bigwin56f100
53-56 bolt in
57-60 the front mount and timing cover have to be swapped to a 53-56 style
61-64 front mount won't work in a 53-56 application, and again the front cover needs to be changed to a 53-56 style
the reason for the front cover to be changed is 57 and up the covers are stamped steel where the 53-56 were cast iron. In the 53-56 the mount bolts directly to the cast iron front cover
The bell housing side is all the same 53-64 except you can't use a 53-56 bell housing in a 57 and up application as the earlier bell housing doesn't have provisions for the 57-60 slave cyl mounting or the 61-64 clutch z bar mount. The 57-64 bells work fine in a 53-56 application
Old May 24, 2023 | 08:23 AM
Turkeytruck
2nd Gear
Thanks for the help
Thanks for the help! engine number is C3ae-6015-F it’s a 64 223 I believe and it’s going into a 55 frame. I’ll update you when I check out my truck this morning.
Aran clyne
New Member Introductions
Nov 11, 2018 09:04 AM
jays '56 f-100
Site Announcements
Oct 19, 2017 02:10 PM
justywheels71
Aug 12, 2004 09:02 PM
