Wiper linkage
Old May 20, 2023 | 08:09 PM
joes99's Avatar
joes99
Wiper linkage
Does anyone have the wiper linkage diagram? I did not get a shop manual because 95% would not pertain to my build. I can make the drivers side work but the passenger arm jambs when I attach it. I assume my connections at the motor aren't correct even with the Dennis Carpenter clevice. Thanks in advance.
Old May 21, 2023 | 07:01 PM
spurredon's Avatar
spurredon
Are you using vacuum or electric? The two are not compatible!
Old May 22, 2023 | 04:34 AM
joes99's Avatar
joes99
I am using an electric motor. I have the linkages from the vacuum setup with a new center clevis.
Old May 22, 2023 | 07:40 PM
spurredon's Avatar
spurredon
My setup was a little different. I had the linkage for the electric motor and tried to make it work with a vacuum motor but no go. So, I then got an electric motor and it worked out for me!
Old May 23, 2023 | 05:47 PM
joes99's Avatar
joes99
Is the electric motor linkages straight? I have two set that are bent and match identically. I thought the one came from an electric set up, could be wrong.
Old May 23, 2023 | 07:30 PM
spurredon's Avatar
spurredon
To be honest I can't remember what their shape was. I would think a parts master catalog would show any differences between electric and vacuum linkages. I'll try to look that up tomorrow!
Old May 26, 2023 | 04:00 PM
spurredon's Avatar
spurredon
Finally remembered to look up the linkages. Looks like the vacuum are straight and the electric have an angle or two in them. A Parts Master Book is a valuable resource. Thet also come on CD.
Old May 26, 2023 | 06:49 PM
joes99's Avatar
joes99
Thanks spurredon, I appreciate your time to get that for me. It looks like I have all of the right pieces. I tried to manually rotate the passenger side and it has some interference in there somewhere.
Old May 28, 2023 | 11:07 AM
joes99's Avatar
joes99
Got them working. the arm at the motor was rubbing the sound barrier and the a/c bracket slightly. The main problem was the arm attached at the motor needed to be aimed at 9:00 position to get the arms both in sequence. Overtighten at the motor and it was spinning causing loss of sequence.
Thanks again for the diagram
Old May 28, 2023 | 07:15 PM
spurredon's Avatar
spurredon
Glad it worked out. These simple old things can really make you scratch your head.
Old Jun 6, 2023 | 12:08 AM
Mike Bonham's Avatar
Mike Bonham
Need wiper help.1959 Ford B600
Two Stubbs sticking out above windshield. Help needed plz
Old Jun 6, 2023 | 11:52 AM
Mike Bonham
Parts master book on CD
How can I get a parts master book on CD for 1959 B600 or F600
Old Jun 6, 2023 | 06:56 PM
spurredon's Avatar
spurredon
Here's one on USB: 1957-63 Ford Truck Master Parts and Accessory Catalog (USB) | eBay
Old Jun 7, 2023 | 07:10 PM
Mike Bonham
Thank You
What a great help you are! Yes this USB option would be fantastic. I ordered a CD and it’s on the way. I’ll check it out and buy the USD if I need. May buy it anyway.
Old Jun 8, 2023 | 07:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957/63 Ford Truck Parts Catalog is available on a C/D from hipoparts.com
CapePowder
1997 - 2003 F150
Jan 6, 2010 12:58 PM
rsylvstr
1997 - 2003 F150
Jan 19, 2007 06:45 PM
seventy2002
Jan 24, 2006 11:35 PM
sarkis
Aerostar
Nov 17, 2003 07:11 PM
