Anyone using amsoil dual guard by pass filter on a 6.7?
Not clear if diesel soot if mostly sub micron or if the problem that the ratio to soot being produced vs the single pass ability to crystal clear the oil is weak.
I think I saw a grants paper toilet roll style video that did a pretty good job of cleaning the oil.
the amsoil display advertisement video shows that the by pass filter can crystal clear oil which has had 5 micron or greater particles poured into it. It does this almost instantly.
Between 6 and 30 nm
Soot forms during incomplete combustion from precursor molecules such as acetylene. It consists of agglomerated nanoparticles with diameters between 6 and 30 nm.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABIAAAASCAYAAAB Wzo5XAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJc EhZcwAADsIAAA7CARUoSoAAAAJ4SURBVDhPrVS/aypBEL7CKlgItiL2gkXqIHZWmk7wdQlBkEBCQEFRJKQSjX+A2B gkVdJpkXQhIBapUqQQBS0EiWKRwsQkN3Nvvnl3R96PdO+DvZ2Z nW92Znb3DMA0zR9ENLUEMpsyHLA9A19l0/adgqtBmHkPRpmdAN+R/5LBsbl7CDT+/Py03t/fzY+PD/UCIIuNZc3RGTbJQHXYwQEXMRDoN4iPTvjYuwH0Rf4njMfHRyqV Slwul7lSqfB4PLYmkwnn83nYrNvbW57P59xoNKzj42O+ubnhxW Jhic6FQkE5w+GQDEmPWq0WSbvo5OQEWTPSPzg4gI0Hg4Fmk8vl eHt7mySo6hcXF+T3+6nX69Hb2xuhNF2IxWIUiUTckpbLJfl8Pj 47O9P1RCLByB4ycH5+Tqenp6pjYwNNhNLtdhkZXF9fQ1WIoxUM BrlarbKUpTYh8WazwcY8Go2UKw1nQ2uRrHAK4XCYdnZ2dBGQXn AoFCKM6XTq2tvtNmcyGc3GOWkNBAXGZrOpfen3+24Jh4eH5PV6 abVauYFSqRTf39+7ZTmB9MhhXK/XHAgErGQyqfrr66u1u7urJdfrdZisu7s7TqfTKjtcDM0IQGlYr NVqINJsNqNOp8PFYpEw0HisHx0d0dXVlcpONoAbCMDi8/Mzb21tkexKKEEaShgej4ez2Szt7++TNBuHq8/EgRNI00P3EQwXDeVIJlAVcq8s2C4vL9UHvg4PAfQeOUCqcHp6e qJoNIpMlAQ8PDxwPB6nl5cX9bEpCsTQRyvjz98HSeMxubuID+6 Pkr7ABFeGPtpvfyO4fLaossDWfvmAY3P3pOz/8WMzjJ9gB1NXubff7AAAAABJRU5ErkJggg==[/img]
Wikipedia
https://en.wikipedia.org/wiki/Soot
Soot - Wikipedia
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAGAAAABgCAMAAAD VRocKAAAAhFBMVEVHcEwQbb4QaL8Qbb0Qbb0Qbr8Qbb0Qbr4Qc L8Qbr4QcL8Qbr8QbLsQbr0Qbr4QcL8Qar8QaroQbb0QbLwQbr4 Qbr4Qb78Qb70QbrwQb78Qb74QbrwQb78Qcb4QcL8Qbb8Qbb8Qb r7////h7fcugMbD2+/D2u8fd8KlyefS5PNqpNZ4rdrw0pEbAAAAIXRSTlMAvyCvYF9w3 xDvIG9AkM9AMDCfULCgj4+gn8+Qr09QYJ9RhAoOAAACLElEQVR 4AcWaCXLbMAxFQWsBaS3e4qRJun3ZTrrc/371dNrB1PVYFMWfvAPgCR8ULdGSOPyqeS56DTgT1BXPzcpLLvy XreIK/bZaZKjeONzAzXSsHEYpPqdfvCIKrSSFJuAMTbFSnKEplgUms50 w7srSYTTh75HIg4+KR5GMRsS0DpiBbkbjx0xGBtFgNjWrvhlG8 6GltEYmNnHrM51wdbV6RTbUXxHcIyMP8h8lslLdGABnDB+QmYI UkNH+I1BkR0kNGDWnASN4TgNGPamB19PhdEycwg4RfBuG4XBE0 kIqEMFhmG5wf25ixHAaEgx+woiPBzNMHLMDzeAsIZLBW0IcQ2n 7KMfwVUR6EA0q4gGmwcsKYBpaqQGmoZYOYBo6KQCm4U4cwDQ8i QJMg0oAmIYgMBIMrxjDBEmGnzAogh8wRgSsIdCHzF+mPbU+HH2 roG92/O26pdZHy//JFGXWfxKRPbE+HtkPXpWIeGJ9LPgPv2dqQn1LKDqj71Z/UkLRGaXUv5PfxN3Mp+n18WnKa+zxZXhJfY2VGhTszMgHEFARbg vVWx7nSAtQGjAKZObx8lAwZA5owT/WvKRDRro3PVq2MXAGYGyQibUYjEGXckHmLaMW4RmsPi2lUkbYK GYQ1u//V6OI75BI5yWOUpPi2Uk0yz0m89HiYTShrZyhKYItfoZCGy+J7A qM4lqZw7J0N6vbxc9x7PuryWxLL7nwbdMV7u/nP33RNW1k8V88Gp9YBCyz4wAAAABJRU5ErkJggg==[/img]
See all
Soot - Wikipedia
https://en.wikipedia.org/wiki/SootSoot particles have diameters between 6 and 30 nm and can be mixed with metal oxides and minerals and coated with sulfuric acid1. Soot is a type of particle pollution known as PM 2.5, which is particulate matter 2.5 micrometers in diameter or smaller2. The size of soot particles varies from 94 to 1000 Å and soot agglomerates have no definite size and shape3. Soot particles in lubricating oil have a mass weighted median diameter of 0.12 to 0.27 μm and a geometrical standard deviation from 2.4 to 4.0, dependent on the type of engine4. Soot contains PAHs, which are known mutagens and are classified as a "known human carcinogen" by the International Agency for Research on Cancer (IARC)5.
Not sure what all that means... but it sure as hell sounds **** ing way smaller than 1 micron. I'm sure if one were to delete the engine, take the EGR out of the equation which would take the majority of the soot out of the oil, the oil would look cleaner... But soot under a micron is really not causing the wear and tear like the bigger wear metal particles are... maybe someone smarter than myself can quote the average clearance size in the 6.7 Powerstroke engine and I bet a bypass filter will catch particles smaller than that.
In 40 years of changing oil in various size engines in my vehicles I have yet to have issues with the brand of oil I use. I believe as long as you are changing the oil and oil filter at the prescribed maintenance for the vehicle there is no need for fancy gidgets and gadjets that are sold at extravagant costs including oils such as Amsoil.
I'm just glad that engine oil has gotten to the point that 3,000 mile oil changes are a thing of the past. Heck, now I usually go a year between oil changes (or 10,000 miles) since I use Mobil 1 Synthetic and Mobil 1 oil filters. Except for my F250 which I change at 7,500 miles.
oil change intervals
the last time I checked, there were 500 6.7 engine blocks on back order at ford dealership repair shops for bearings and other failures. Driving til the oil monitor light says to change your oil with oem stock supplies did not work well for them.
Received 1,458 Likes
on
there’s no general one size fits all rule….some folks are metro drivers where they have to stop and idle every city block and only run short trips except for the few times of the year they do some towing , hauling, etc. other fold can dive all day at the speed limit, rarely stoping and idling.
So how's a bypass filtration system going to extend engine life on your driving scenario? And how would it have prevented those 500 6.7 failures that are waiting for replacements?
Just to be devils advocate, that is making the assumption the 500 engine failures were due to people running the OLM to zero. We don't know how many of those were some other issue, such as running it well beyond the OLM, oil contamination with something else, dumping in crisco instead of CK-4, etc, etc.
Since we were talking about soot particles and their size, in my search for more info, I came across this... interesting.
https://unece.org/DAM/trans/doc/2011...PMP-26-08e.pdf
Nanosize Metal Oxide Particles emitted by Diesel- and Petrol-Engines
EU-PMP, ISPRA Dec.6.2011
Summing it up:
"Conclusions
-- Internal combustion engines emit metal oxide particles from engine wear and lubrication oil
-- metal oxides are probably more toxic than EC (soot)
-- PM can be 0.1-1 mg/km -> PN >108 #/cc -> 1014 #/kWh
-- Size around 20 nm, insoluble and toxic
-- health concern is justified Measures:
-- deploy efficient Particle Filter Systems on all ICE
-- reduce the metal content of the lubrication oil
-- extend PN-measurement to particle sizes < 23 nm
Summing it up:
"Conclusions
Summing it up:
"Conclusions
Summing it up:
"Conclusions
yes…especially since a lot of the oil goes into the intake via ccv system…I’d rather have highly filter 2 micron oil going into my intake than 20 micron filtered oil.
on
Summing it up:
"Conclusions
Summing it up:
"Conclusions
The following users liked this post:
#29
I have a toilet paper bypass filter. Like all bypass systems the oil still does turn black but is clean of any particles larger than 1 micron. Filter replacements also cost around $1. I haven't really been able to extend OCI though because of fuel dilution (thanks, EPA!).
Agreed! Those **** ers!
#30
If that was the case then it wouldn't have mattered when they changed the oil.
