Sponsored by: Auxito
Need help quickly
Old May 19, 2023 | 07:17 PM
Staffordsfordproblems's Avatar
2nd Gear
Need help quickly
I have a 94 F150 4x4 I was driving it pulled up to house hit 4 wheel drive button and now my truck is like inn neutral. When I shift down into drive it sound like engine engages, but it’s like it’s stuck in neutral. I can unhook batt cable for a bit then jump in and it will go into gear for a sec move around then pop nothing. Before it never slipped or anything
Old May 20, 2023 | 04:49 AM
manicmechanic007's Avatar
manicmechanic007
Sounds like you need a new transfer case shift motor
When the limit switches malfunction, you get a no shift condition
It needs to know where it is at to allow a shift
There are a few parameters that must be met for 4x4 low operation
There is a chance you hit the button twice or the low button if equipped?
Either way, the park brake must be applied and it in park or neutral with a 5 speed to engage low range
There are a few strategies oner the years, you try the park brake trick and maybe it will come out of it
You can pull the motor off the back of the transfer case and manually shift it to unstrand yourself using pliers
Old May 20, 2023 | 07:30 AM
WWR's Avatar
WWR
Here's a good troubleshooting explanation for the electric shift BW1356:
1989 Ford Truck F 250 4WD Pickup V8-460 7.5L - Diagnosis of the Electric Shift 4 X 4
justin53
Jun 17, 2022 11:19 AM
harreil
Apr 3, 2022 07:46 PM
78fordbeast
Jul 17, 2012 06:55 PM
provosc
Nov 8, 2010 02:33 PM
00Eddie
Jun 26, 2006 10:52 AM
