Sponsored by: Auxito
No crank
Old May 18, 2023 | 08:35 AM
Notamechanic2002's Avatar
Notamechanic2002
4th Gear
No crank
I have a 2002 f150 4x4 with 5.4. recently put crate motor in was cranking from seat now will not. I can jump silinoid over but not getting power from ignition to silinoid and half of my fuse panel is dead. Anyone have any idea one where to start trouble shooting this problem.
Old May 18, 2023 | 02:29 PM
TerryJ1517's Avatar
TerryJ1517
Trailering
When you say fuse panel are you talking about the one under the dash or the one in the engine compartment. I'd check the fuses in the power distribution box in the engine compartment first if your fuse panel under the dash is half dead.
Old May 18, 2023 | 02:34 PM
Notamechanic2002
4th Gear
The one under dash is half dead all under hood shows to be good with test light and visual
Old May 18, 2023 | 05:34 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Find which fuse was popped. No cluster = no PATS handshake = dead in driveway.
https://sparkys-answers.com/2016/03/...ification.html
ETA: Read that as cluster was half dead. Somewhere under the dash, something got disconnected. The GEM would control some of the important stuff as well.
Old May 18, 2023 | 05:38 PM
Notamechanic2002
4th Gear
No fuses were popped I've checked them with a test light and pulled each one and looked at them under the hood and under the dash
Old May 18, 2023 | 07:46 PM
TerryJ1517's Avatar
TerryJ1517
Trailering
When you say you jumped the solenoid, did the engine crank over????
When you put the ignition switch in the start position, the voltage is routed to fuse 21 (15A), if your truck is has a "remote anti-theft personality module" then there is a "Starter interrupt relay" which is engaged by the RAP module. If no RAP module then the voltage is supplied to the DTR (digital transmission ranger sensor), from there it goes to the Starter motor relay (solenoid)
rbtom
Jan 2, 2015 05:50 PM
Moto52
Sep 26, 2011 09:54 PM
seanj5202
Apr 8, 2011 05:50 PM
Hello
Apr 17, 2005 06:31 PM
seamac
1983 - 2012 Ranger & B-Series
Jan 7, 2001 02:58 PM
