Sponsored by: Real Truck
2006 floorboards
Old May 15, 2023 | 10:03 PM
mkelee's Avatar
mkelee
4wd High
2006 floorboards
My F-350 Super duty has floorboards I have not seen before, can't find in online catalogs. I am currently working on the exterior, repaint on the AZ Beige and replacing plastics and bumpers.
The floorboards are a problem there are ford stamps on them, made in Canada stamp and a part # XO35-16N454-AFW (same # on both boards). There are lights front and back and polished diamond late covers that fit on an Az Beige board. I cannot find anything on the web.......... Anyone have any Ideas? THANK YOU
Old May 16, 2023 | 07:28 AM
speedfreak78's Avatar
speedfreak78
That PN is - XC3S-16N454-AFW
The new PN seems to be - XC3Z-16N454-AFW, but there still aren't alot of results
https://www.google.com/search?client...ih=646&dpr=1.2
I'm guessing the diamond plate covers are an aftermarket add-on
Old May 16, 2023 | 02:35 PM
mkelee's Avatar
mkelee
4wd High
2006 Running boards.
Thanks for the response speedfreak78. The truck was my fathers, it came new with the floor boards and if you look at the pictures the AZ Biege piece has square holes, There are threaded studs on the back of diamond plate that fit in the holes and go thru the running board frame and bolt on. I will send more pics when I get home from work.
Old May 16, 2023 | 10:50 PM
mkelee's Avatar
mkelee
4wd High
There is no ford stamp on the inserts just on the Az beige board I cannot find the lights either, I can polish out the inserts but the plastics are shot and faded out, discolored.
Old May 18, 2023 | 10:40 AM
mkelee's Avatar
mkelee
4wd High
Is anyone familiar with any chemicals I can use to restore? I have found the boards in black but I cannot find any trace of Beige boards, I have used 303 in the past on plastics but it washes out pretty easy, I have used plastic dye's but have only seen Black.....
Cutterbuck
Nov 10, 2019 04:50 PM
pdx.puddle
Jan 13, 2017 09:21 AM
ThA CoPyCaT©
Apr 18, 2011 06:13 AM
Devil1984
2004 - 2008 F150
Jan 28, 2011 02:35 PM
Hummerkiller
Texas Chapter
Mar 6, 2006 11:50 PM
