New Ceramatallic LUK clutch? Wrong clutch? Slipping?
#33
I also still only have one set of bolts for the drive shaft. I don't have enough to do the front and rear drive shaft. The only problem with that is I could not take my front drive shaft all the way off because, the cap bolts that hold the U-joint on to the front differential rounded off when I try to take them off last. So the front drive shaft is currently stuck on which is fine, I don't plan on taking it off however it made removing the transmission a little more annoying and I have to leave it on so I need to get another set of bolts for the rear drive shaft. My dad has got two four wheel drive F-150s in the yard and one of them is for parts and he said I was welcome to take a set of drive shaft bolts off of one of them however, I don't know if they are going to be the same in terms of being a 12 grade Bolt. Who knows?
#34
you ain't lying there. This is the third time. I got me a couple cans of carb cleaner and spent some time cleaning up making sure there is no contaminants anywhere and I have been putting coats of paint on my rear drive shaft as I go. I'm on the 4th coat now. Transmission went right in this time pretty much. Still have a couple more bolts in the shift tower to put on.
The following users liked this post:
afman87
04-27-2009 10:32 PM
grease monkey
03-19-2005 06:39 AM
