lift gate issue locking
Old May 11, 2023 | 04:10 AM
mackendw's Avatar
mackendw
Have an 87 ford f150 with the 5.0L. Issue is with the passenger side lift gate lock mechanism that is spring loaded. Mine is not grabbing the spline stud on the side of the box so that side can be moved in/out and rattles. The drivers side latches properly. I cleaned the spring out and lubed it with silicon lubricant. Still not latching. Is this a common issue? fix is to replace that latch mechanism?
Old May 11, 2023 | 08:04 AM
My4Fordtrucks's Avatar
My4Fordtrucks
With the tailgate down, use a screwdriver, 3/8” extension or something else to close the latch. Does it fully close and stay closed?
Old May 11, 2023 | 08:49 AM
mackendw's Avatar
mackendw
Yes, I can move the hook into the locked position and it will stay but when I close the tailgate that hook part doesn't wrap around it.
Old May 11, 2023 | 09:20 AM
My4Fordtrucks
Did it latch before or is this a new problem? The striker pin on the body is adjustable.
Old May 11, 2023 | 10:30 AM
mackendw's Avatar
mackendw
If I close it, it stays shut...the issue is the right side (passenger) has around 1-2" of movement because the locking clasp is not going around the striker pin. You say
the pin is adjustable eh? how is that accomplished?
Old May 11, 2023 | 03:01 PM
My4Fordtrucks
That’s not what is asked. Is the passenger side not latching new or not? With a Torx bit
Old May 11, 2023 | 03:37 PM
mackendw's Avatar
mackendw
No, the passenger side latch is not connecting with the pin. I'll have to procure a T50 TORX bit I guess...I saw a video of the setup
of the pin ...and there does appear to be some wiggle room to move it to meet the locking claw.
Old May 12, 2023 | 07:24 AM
mackendw's Avatar
mackendw
fixed!
Adjusting the post on the fender sidewall did the trick. thx. a bunch.
PupnDuck
Escape & Escape Hybrid
Oct 22, 2019 05:20 PM
bf250
May 7, 2006 05:09 PM
rguy
Bronco II
Aug 3, 2004 01:24 PM
