This is all I really seen aside from a stamped ford symbol and a number stamped that looked like 1
The only identification I could see aside from those stamps was one that looked like it said 1. The truck is a 1983 Ford f150 300 inline 6 4x4 standard cab.
I also found this documentation
https://www.garysgaragemahal.com/axle-ratios.html
What rebuild kits fits this and or how else can I identify it? Tia
Ford 8.8. Casting numbers are not going to be a great deal of help and you can safely assume somebody has been in it already because there is no tag on the cover bolts. All is not lost however. Check the certification label in the door jamb and tell us what the axle code is.
Here’s the vin tag and it looks like the it says the axle is 18? Like you said tho I’m sure someone else has been in there and was not sure if this was the stock differential. I highlighted axle 18 and yr 83 on the chart. Does this help?
Looks like it is a 3.08 ratio 8.8 Ford rearend. More than likely it's original, since it's a 4x4. If they swapped the rearend out it would have to match the front differential. Have you ever had it in 4x4 and it worked ok?
Yes it I drove it in 4 low but it seemed like I was driving my manual and letting off the clutch to soon. I also drove it in 4 high but it seemed fine in 4h. Granted I’ve never owned a 4wd or know anything about manual locking hubs. The kid I bought it from showed me everything I know about them.
I recently bought the truck due to loving the bull nose look and looking for a project. I only drove the truck from where I bough to my home which was about a hr ride.
30 mins of 65-75mph and about 30 mins of driving through town.
I noticed that seal was leaking where the “pinion seal”? Is hence this post
The only other problem I’m having is I think the transmission needs replaced. After the transmission swaps to third gear and you let off the gas you hear a lot of clunking. So I was going like 75 perfectly fine but when I left off the gas grinding noise pursued as soon as you accelerate tho it disappears. So from 50 up as soon as you let off.
Sounds like ujoints to me. From your certification label, transmission code K is a C6. If you make it to 75 mph with a 300 and a C6, I'm pretty sure the engine and transmission are reasonably solid.
I have not seen Ujoints make noise when off the throttle only when under power.
when under power beside making noise they can also vibrate just before they come apart all together.
It is hard to pin point a noise on this side of the computer.
I would check the oil levels in the front & rear axles, transfer case and transmission.
Dave ----
A slow down whine could be your transmission or your rear end. With the leak it could be low in the rear end. I think it's possible u joint too but that can be eliminated as the cause by inspection.
I think your noise thunking is coming from your rear end. The picture of the u-joint yoke, the yoke appears to me to be loose. That would be the cause of the leak and allow slack in the rear end.
it could be loose but that looks like the seal got pushed out.
Make sure the axle vent is open.
Dave ----
I think your noise thunking is coming from your rear end...
Please let the record show I am being good and am refraining from making a cheap joke about noises coming from somebody's rear end.
For a noise that changes with coasting or acceleration, I'd certainly first look at the rear differential. Considering it has been puking oil, the gears may very well have run dry and are chewed up. It should be a simple matter to remove the cover and give the gears a good visual inspection.
If the gears are good, definitely take care of that seal at the front. Your life will be much simpler if you can use an impact gun to remove the nut, versus trying to get it with a big breaker bar. After that, you'll need a bolt grip puller to remove the yoke.
After replacing the seal, reassembly creates a quandary. Like nearly any modern differential, a crush sleeve was used for setting the preload on the pinion shaft bearings. By the book, you're not supposed to reuse a crush sleeve, but a lot of guys do. I don't recommend this. The best option is to replace it. Another less known option is to add a shim to the existing crush sleeve, so it takes a new bite, so to speak.
