Another Chucking Thread
Old May 9, 2023 | 03:15 PM
arniet's Avatar
arniet
To the OP, you say 95% fine and dandy, I would just ignore it the other 5%. The chucking hurts nothing. Of course my first employer had me drive partial loads in tube trailers. They had a very lively ride. My wife has only known our 5er for the past 11 years, I just tell her that is the way it is, and drive on. Soon, you will not notice it.
Old May 12, 2023 | 04:09 PM
MKrenn's Avatar
MKrenn
Hey Ken, I have the Torklift Stableloads and really like those over the air bag setup I had on my last F-350. Same 5th wheel too. Just a thought.....
Old May 12, 2023 | 06:03 PM
kshoop1958's Avatar
kshoop1958
Thanks, I'll check it out!
Old May 12, 2023 | 08:01 PM
acdii's Avatar
acdii
You should try to get the front axle even loaded/unloaded. Try moving the hitch up to the 3" forward position. By removing weight off the front, it can increase movement rearward which adds to the porpoising effect. Adding air bags will not transfer the weight forward, they just take up some of the weight and place it directly on the axle and off the springs, adding a cushion while raising the rear. Getting more weight forward on the trailer will stop the seesaw effect which is what causes the porpoising and chucking. Fill your water tank too if you don't, that added weight helps. Just make sure it is fully filled, a half tank can slosh and make it do silly things at a stop.
Old May 23, 2023 | 03:14 PM
arniet's Avatar
arniet
Good advice from Acdii, unless your camper is like mine. My fresh water tank is behind my axles, right at the back of the trailer, it is a rear kitchen. So filling the tank teeters my totter. I wind up with less pin weight and more on the trailer axles.
Old May 24, 2023 | 11:42 AM
kshoop1958's Avatar
kshoop1958
Yeah, my fresh water tank is in the back so that won’t help with pin weight. If I can find a solution that doesn’t require extra weight I’d prefer that, just because of gas mileage.
Old May 24, 2023 | 01:41 PM
acdii's Avatar
acdii
Extra weight doesn't impact fuel economy as much as you might think. The wind resistance is the biggest killer of fuel economy. I towed my flatbed to Tennessee from Rockford, noted the MPG, loaded a no-till drill that stuck up above the tailgate, and noted the MPG on the way back. it was .7 of a MPG difference mainly due to the wind resistance against the drill. Another time I had picked up a bundle of shingles that weighed 1300 pounds and the MPG was exact both ways.
Old May 29, 2023 | 09:24 AM
kshoop1958's Avatar
kshoop1958
Just a quick note to follow up on this with some additional info. Our trip this past week was fairly close to home so no interstate driving, just state routes and local roads. Happy to report the ride was fine, which has me leaning towards the "If it ain't broke, don't fix it" camp. The roads were far from perfect so it seems to me the chucking/porpoising only occurs at high (65 mph) speeds and really bad bumps. I did think to measure the squat this time, it's about 2" at the center of the rear wheels. Honestly though, I don't know if that's normal or too much.
Old May 30, 2023 | 02:48 PM
MKrenn's Avatar
MKrenn
Sounds normal to me Ken.....
Firefighter 1406
Sep 12, 2022 08:55 AM
FordySumthin
All Things Towing
Jul 8, 2022 07:14 PM
f150crewcab
All Other Items for Sale
Sep 20, 2012 11:20 AM
mechelement
May 22, 2012 07:13 AM
StreamlineGT
Connecticut Chapter
18
Jul 11, 2010 04:57 PM
