Speedometer not reading right
Old Apr 25, 2023 | 02:40 PM
Anonymous12's Avatar
Anonymous12
I have a 1988 f150. It does not have the stock 235/75/r15 tires. It has the 31x10.5r15 tires. When I drive my other car going the speed limit in the fast lane people will stay behind me. But if I do that going 10 over according to my trucks speedometer everybody passes me. I downloaded a speedometer app for now. How do I calibrate the speedometer?
ill put the specs below:
31x10.5r15 tires
3.55 rear end
Aod transmission
302 v8
and it has the gauge cluster without the tac
Old Apr 25, 2023 | 03:26 PM
yeet's Avatar
yeet
Sorry, for some reason the link is not working. Go to youtube and punch in "How to calibrate your Ford PSOM"
A few good videos on the procedure. It's not real complicated.
Old Apr 25, 2023 | 03:35 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The speedometer is driven by a cable connected to either the rear of the transmission (2wd) or transfer case (4wd). Remove the speed sensor/cable assembly from the trans/transfer case to see what color driven gear is currently in the truck. That will tell you how many teeth.
I looked online at a calculator to figure out what driven gear I would need to correct the speedometer when changing to 4.10 from 3.55 gears. I’m not sure which website I used.
R&RFord's Avatar
R&RFord
On the pre 92 trucks there is no PSOM. The speedo runs off a cable from a little gear housing in the transmission or transfer case output housing. There is a gear that needs to be changed to match the new tire height or change the tire height to match the installed gear.
Old Apr 25, 2023 | 03:36 PM
My4Fordtrucks
Originally Posted by yeet
How to Calibrate Your Ford PSOM (P'ing OBS Trucks) - YouTube
Nope. No PSOM in ‘88
Old Apr 25, 2023 | 03:51 PM
maco's Avatar
maco
A today real simple way... go on a tire calculator site & compare your original tire size to the new size...It will tell you how much faster/slower the new size is reading.
Subtract the 2 speeds given that is your difference ...When driving ad/subtract this difference ...That will be your actual speed....Rember a bigger tire will register a slower speedo speed.....so you will need to add the difference each time you look @ the speedo....
JimmyWayne23
16
Jul 30, 2022 12:57 PM
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
6brau
May 24, 2013 12:48 PM
nitropolaris2
1997 - 2003 F150
Nov 2, 2004 11:40 PM
WALLDOG18
1978 - 1996 Big Bronco
Aug 18, 2002 02:55 PM
