Bed markings
Old Apr 23, 2023 | 11:00 PM
Edd505's Avatar
Edd505
Bed markings
I just bought a 2022 F350 Lariat CCLB four wheel drive with super low miles, 7000, from a large Hyundai dealer. I know the 4FX is 4x4 skid plates, 4X4 is what it says. There are no makings on the bed, cosmetic I know, but is there a meaning to no making? Car Fax shows no accidents one owner so I don't think its a repaired and the decals left off. What say you Ford experts?
Old Apr 23, 2023 | 11:36 PM
4wd6.7L's Avatar
4wd6.7L
The previous owner probably didn't like stickers and removed them. The non FX4 4wd trucks all come from the factory with "4x4" on the bedside.
Old Apr 23, 2023 | 11:46 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Are you saying your truck is a FX4, but it has plain 4x4 stickers on the bed?
Skid plates alone don’t mean it’s a FX4, as they could be added as a stand-alone option. Easiest way to tell if your truck is a FX4 is to see if it has a hill decent control button on the dash above the center screen.
Old Apr 24, 2023 | 12:19 AM
HRTKD's Avatar
HRTKD
I took off the 4x4 sticker on the bed so I didn't have to deal with wax getting stuck around the edges. It was very easy to remove. I would take everything else off if it was that easy but the badges are attached better.
Old Apr 24, 2023 | 05:41 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Sounds like the original owner simply removed the decals. Like ATC mentioned, looking for a Hill Descent button could tell you if it’s an FX4, however that still won’t say for sure. I added the Hill Descent button to my non-FX4 since it was so inexpensive and easy to do. The best way to tell is to look at the window sticker.
Old Apr 24, 2023 | 06:19 AM
ToMang07's Avatar
ToMang07
Could always pull up the sticker and see the full build.
Old Apr 24, 2023 | 08:04 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Add your VIN to the end of this url> https://www.windowsticker.forddirect...icker.pdf?vin= to see your original window sticker.
Old Apr 24, 2023 | 08:47 AM
2004Limited's Avatar
2004Limited
That’s the first thing I did to my 2019! Much cleaner look to me.
Old Apr 24, 2023 | 10:38 AM
JBoerger's Avatar
JBoerger
Sticker hater
Ditto on this. Pulled the 4x4 stickers - 1st thing I did when I brought it home. BTW, I ordered it with the skid plates (for $100), the AT tires, swapped out the stock shocks for Bilstein 5100's @ 60 mi, and installed the hill descent button (and rearranged those buttons too). I will add hill descent via Forscan. Voila! FX4 with better shocks and without the sticker.
Old Apr 24, 2023 | 10:41 AM
Edd505's Avatar
Edd505
Thanks for all the reply's, I have the hill decent button and the normal 4 wheel buttons to shift. The build sheet shows special ordered and optional equipment 618A and a list of included in that package. I have not been under yet to see if it has skid plates or not. I was curious as I normally see the decals for FX4 or just 4X4 and didn't know what I have. Today it gets the though inspection with book in hand to see how all the "options" work. I noticed it has auto dim headlights on the way home after the first the light changed I watched closer and then found that in the manual. With all the bells and whistles I might need a pilots license.
Old Apr 24, 2023 | 08:28 PM
chipone's Avatar
chipone
hrtkd how did you remove them? Tool?
Thanks!!
Old Apr 24, 2023 | 09:12 PM
2004Limited
Thanks!!
I just borrowed the wifes hair dryer, warmed it up, and just pulled it off. Wiped with WD40, and repeat the process on the other side, and your done.
Old Apr 24, 2023 | 09:35 PM
HRTKD's Avatar
HRTKD
Exactly what I did.
Old Apr 25, 2023 | 04:51 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
No way I’d remove my FX4 logos
I’m old school.
To each his own I guess
Old Apr 25, 2023 | 10:24 AM
chipone's Avatar
chipone
wow sounds good!! Thanks
