Turn signal
Old Nov 17, 2003 | 02:08 PM
95se5m's Avatar
95se5m
Turn signal
Lo all. I just recently changed my ignition switch actuator on my truck. While the column was apart the little end on the turn signal switch broke. The C shapped part of the item pivits on a bolt.
Anyone know if I can just replace this part? I found 2 in the junkyard but the wiring harness was cut, big supprise. Anyway, can I just replace the C shaped part? Any thoughts would be great. I can use the truck, but I have to hold the right turn in place. As you can imagin driving a stick, it's challenging to say the least.
