No headlights
Old Apr 19, 2023 | 05:36 PM
Wvarian's Avatar
Wvarian
2nd Gear
No headlights
89 F250 diesel
Both headlights are out, all other lights work.
Changed out dimmer switch.
Have 12V to plugs for lamps.
Voltage comes and goes with switch being turned on and off.
Have continuity to negative side
Bought a new bulb just to check no light
Old Apr 19, 2023 | 05:42 PM
Mo8414's Avatar
Mo8414
Try a new headlight switch
Old Apr 19, 2023 | 07:18 PM
wwhite's Avatar
wwhite
Bad ground on light plug, and or rad support.
Bad plug, dirty corroded connections.
Highly unlikely, but bench test each head lamp.
Old Apr 20, 2023 | 04:31 PM
manicmechanic007's Avatar
manicmechanic007
I have seen intermittent bad connection in the headlight connector itself
I have seen a bunch of them with a burnt headlight switch connector
I'd pull the headlamp switch and check for a burnt connector first
After you see that, replace both the switch and the connector
Old Apr 20, 2023 | 07:59 PM
Wvarian's Avatar
Wvarian
2nd Gear
Fixed
Update
issue fixed
Replaced dimmer floor switch
Replaced headlight switch
Lights work
Still confused as to how I had voltage at the lamps that turned on and off with switch operation.
The headlight switch that was in was only 3 years old, had replaced it when the plug burned up.
Regardless problem solved.
GarageFab
Feb 15, 2010 10:17 AM
91FordF250
Feb 23, 2005 04:39 PM
d0n_3d
1983 - 2012 Ranger & B-Series
Dec 1, 2003 12:19 AM
caver
Electrical Systems/Wiring
30
May 6, 2003 06:31 PM
