Newbie
Old Apr 16, 2023 | 10:26 AM
DDD DDD's Avatar
DDD DDD
1st Gear
Newbie
Howdy, I’m DDD but someone already had that usually means so now I am DDD DDD. I have just picked up a 1989 Ford F350 custom pick up truck diesel, with the 8 foot bed standard cab with 70,000 miles and a plow not bad for 6K I also have a 1997 bronco XL completely restored I also have a 95 bronco XLT, which is all souped up tricked out Big tires and all that other BS. If anyone knows anything about Ford truck keys the set I got with his latest F350 they are different cuts in the keys between the top and the bottom which are supposed to be completely reversible and match completely. Since this is true about the ignition key and the doors/glove box key, I believe this is actually a master set that is reversible to cover a number of different models such as you know, a master key in a building . I know these things exist because a mechanic once left a set of his keys in my mothers, Ford escort, and from then on, I always had keys that could start any truck in our yard whether it was an F550 an E250 it didn’t matter even Rangers So is there any way to get the original key code because if memory serves a member hearing that there prior to the 90s they were only ever about 15 possible key combinations per model year per basic line of vehicles. Anyway, nice forum forum.
Old Apr 16, 2023 | 06:45 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. Try posting your query in the Miscellaneous section, under electrical/wiring. There may be some experts there who can help you learn if you are correct of not.
Old Apr 16, 2023 | 10:54 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Quite a collection there! I bet some of us would like to see pictures!
Welcome aboard!
BroncoBrice
New Member Introductions
May 14, 2016 01:00 PM
kristinaleacisneros
Jul 4, 2015 01:32 PM
bronco kid
Mar 29, 2007 05:29 PM
