FM radio (Ford) reception cuts out - 1996
Hi! I've got a 96 Ford F-150 with Ford AM/FM cassette radio. I bought it with this problem that the FM radio reception cuts out and doesn't get anything for a couple to several minutes at a time. 90% of the time its ok. When the cut out happens I'm still able to get AM radio...just the FM stations don't come in and are static. Eventually it just kicks in again without me doing anything. I've tried pushing all the button on the radio, etc. while its out but that does nothing. A few weeks ago I has had replaced part of the dash and at that time the guy check all the connections in back of the radio and said it was all ok. And this happens both when the sun is out and raining.
I don't think it's the other end of the antenna otherwise I wouldn't be able to be getting AM...is that right?
Thanks for any help or if anyone knows if this is a circuit problem of some sort with Ford radios from then.
Cash Moline
Austin, TX
Cash Moline
Austin, TX
replacing radio--need help
So steve says it's not too hard to replace the radio. My tape player died, so I went out and bought a JVC and an install kit. Went out today to yank the old unit out and--there are no screws on the trip around the radio! What gives? I couldn't find anything that shows that (dis)assembly in the Haynes manual or the Owner's Bible. Any knowledge here? Thanks.
--Joe, '87 4x4, 158k mi
There should be 4 holes in the corners of the radio. Find 4 nails or slim screw drivers and push them in the holes until you feel a release. Then just give the radio a tug. Going in is even easier(with the same radio), just push it in and your done. Very slick design by ford. Sounds like a cold solder joint in your old radio. I'd fix it, their worth good money.
Just get the uninstall tools from autozone for like 3 bucks. They just stick in four holes on the edge of the radio. They have great pictures on how to do it here http://installdr.com
JumpinJoe
11-22-2009 04:38 PM
Tylus
07-15-2009 11:02 AM
Thudpucker
07-25-2008 05:39 PM
