Quick Question
Old Apr 14, 2023 | 02:09 PM
DieselDog409's Avatar
DieselDog409
Quick Question
Is there a way for me to lift the front of my 1950 ford f5 tow truck as i dont know how to and have made blocks for the back axle already.
No i am not squatting it.
Old Apr 14, 2023 | 10:41 PM
mOROTBREATH's Avatar
mOROTBREATH
Shackle extensions? But you'd have to do something with the steering stuff as well.
Personally I love your blunt humor and language, Your other thread was hilarious, but others may not so you otta be careful with cussing for no real reason.
Old Apr 15, 2023 | 02:47 PM
SRGN's Avatar
SRGN
Few ways to get there, longer shackles as mentioned above, new/re-arched springs, etc. Depends how far you are trying to raise it over stock, or if it's already down and you are trying to get back to stock ride height. If you are going higher than stock, you need to consider other items like the length of the steering arms, also raising it evenly so it doesn't adversely affect the angle of the king pins.
Old Apr 17, 2023 | 07:47 AM
DieselDog409
I want to give it a 2-3 inch lift on the front so it sits higher. Redneck rule of ride height if you can see the seat from outside it is too low.
Old Apr 19, 2023 | 10:43 PM
SRGN's Avatar
SRGN
I would look into new springs, or possibly getting yours re-arched. When you go up, it's going to add some bump steer, so you may want to look into a dropped pitman arm to counter it. If you want to do some major fab work, there's other options, like building a custom 4 link with heim joints and adding a track bar. The sky's the limit at that point.
Old Apr 20, 2023 | 12:44 PM
DieselDog409
could i build drop blocks for the spring mounts and cut and weld the pitman arm?
Old May 10, 2023 | 10:55 AM
DieselDog409
Does anyone have a diagram of the front end on these trucks for me to use for measurements.
Old May 10, 2023 | 11:03 AM
Gicknordon's Avatar
Gicknordon
Many class 8 trucks have blocks on the front axle as well.
Old May 10, 2023 | 11:05 AM
DieselDog409
Ok good to know, but i would still like to have a diagram of some sort.
Lumberman12
Nov 27, 2017 08:53 AM
78_f800crewcab4x4
All Things Towing
Jan 1, 2010 03:52 AM
Kylet8020
Offroad & 4x4
Jan 17, 2008 07:28 AM
hillbilly316
Nov 26, 2004 06:09 AM
