Front pinion angle
Old Apr 11, 2023 | 07:05 PM
PKFARMBOY87's Avatar
PKFARMBOY87
3rd Gear
Front pinion angle
Alright so we just got a 1974 f250. 360 4 speed
The back is lifted but they didn't do anything with the front. I just noticed the pinion is pointed straightish its got a slight down angle to it.
Do I fix that with angled blocks?
First time Ford owner here. I'll try and get pictures asap.
Old Apr 11, 2023 | 07:14 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
It is a Highboy (divorced xfer case and a long front drive shaft)? https://www.ford-trucks.com/forums/9...mpilation.html
And it is a low pinion exit axle? Versus a high pinion exit axle? Like in 77-79 F150 and F250's.
DO NOT PUT BLOCKS ON THE FRONT, IT IS ILLEGAL IN MOST STATES AND JUST PLAIN DUMB. Maybe take the lift out the back, did they double stack the OEM blocks to make it ride high in the back?
Old Apr 11, 2023 | 08:15 PM
440 sixpack's Avatar
440 sixpack
The pinion on a high boy was never angled up. sometimes they are pointed down a bit especially if caster shims are used. it doesn't hurt anything.
Old Apr 12, 2023 | 10:10 AM
speedfreak78's Avatar
speedfreak78
Get an angle gauge and check it. You need to check caster also, you don't want to change pinion angle and throw the caster way out.
Old Apr 12, 2023 | 06:12 PM
PKFARMBOY87
3rd Gear
Well I discovered a lot of the problems today. One the previous owners went weld happy on this truck. The tried to make a spacer for the tcase(to lower it from the frame) out of a couple pieces of angle iron and flat strap. Going to be a little but more of a project than I thought. But still a great first truck for my son.
Old Apr 12, 2023 | 06:46 PM
77&79F250's Avatar
77&79F250
So they tried to fix/make up for the front axle pinion angle by lowering the xfer case. Is the front end suspension stock? You need to post up some pics of what you have going on. A pic is worth a 1000 words.
Outlaw56
Feb 23, 2017 07:58 PM
1978fordf250
Offroad & 4x4
Jan 2, 2007 09:48 PM
therigwelder
May 27, 2005 07:24 AM
kopfenjager
Mar 2, 2005 12:42 AM
atccracing
Nov 2, 2004 07:39 AM
