02 sensor codes
Old Apr 11, 2023 | 12:21 PM
Ronniewhite's Avatar
Ronniewhite
02 sensor codes
I have a 1996 f150xl 4.9 6cyl. I have a p0141 and I tried to change the downstream sensor but no luck so I'm soaking it everyday for a week or so then my buddy who has torches is going to try it. Anyways I checked today just to make sure that was still the only code but now it has p0136 too. I'm pretty sure that is still for the downstream after cat sensor? Just wanted to make sure.
Old Apr 11, 2023 | 01:31 PM
rla2005's Avatar
rla2005
Yes it is: P0136 O2 Sensor Circuit Low Voltage (B1S2)
Old Apr 11, 2023 | 01:56 PM
Ronniewhite
Originally Posted by rla2005
perfect thank you.
Old Apr 11, 2023 | 03:12 PM
yeet's Avatar
yeet
Was the dual 02's a 96 thing only? My 95 only has one.
Old Apr 11, 2023 | 03:29 PM
rla2005's Avatar
rla2005
No it is not. I believe the 1995 5.8L Bronco with CA emissions and BIO0 catch code PCM uses stereo O2 sensors. That one does not use a third O2 sensor behind the converters, that was an OBD-II requirement.
There may be other catch codes in 1995 that used dual O2 sensors, but I do not have that info in front of me at the moment.
Old Apr 11, 2023 | 04:46 PM
Ronniewhite
mine has 3
Redneck1465
Nov 4, 2009 10:00 AM
jellybean66
Mar 1, 2009 01:23 PM
wldcat65
Oct 15, 2006 10:03 PM
Matts66
Mar 17, 2004 07:49 PM
CrazyFordMan
Dec 7, 2003 12:23 AM
