Swapping 4x4 from 94 OBS into 81 bullnose
Before I buy the donor I need you guys to “check my homework” please.
My ride is a 1981 F150, 4x2, 4.9L carb, SROD, single cab, 133” WB
The donor is a 1994 F150, 4x4, 4.9L EFI, 5 speed manual, single cab, 117” WB.
I want to swap the front and rear axles, transfer case and transmission from the ’94 into my ‘81.
I’ll lose the mechanical speedometer, the mechanical clutch and will need a longer rear driveshaft.
Since it’s a 4.9L to 4.9L and F150 to F150 everything “should” bolt up?
Correct?
Correct?
The following users liked this post:
bpieprzak
02-06-2023 11:01 AM
speedfreak78
07-19-2016 07:52 PM
madMatador78
11-25-2015 10:37 AM
triksterut
03-04-2005 05:52 PM
