1995 5.0 timing issue
Old Apr 10, 2023 | 01:17 PM
Nlk9854's Avatar
Nlk9854
1st Gear
Look to see if anyone has delt with this or has some ideas because I'm stumped. I have a 1995 Ford f150 with a 5.0 and 4r70w trans. About 2 weeks ago the truck started to bog down at red lights and run rough but once I'd give it a little gas it would clear right up, this weekend I did a tune up on it plugs(gapped .054), wires, and the cap & rotor. When I timed the engine and set it to 10-12 before TDC it has no power when in drive and is missing. I've gone all over with the timing and have only gotten it to run decent up at 29-33 before TDC but pings when I give it gas in drive.... Where I'm confused at is the engine will rev up fine in park(I'm not sure about neutral). I'm sure it's a sensor but every sensor that I can think of that's related to it is around 100 bucks per, any ideas would be appreciated
And yes I timed it with the spout removed
Old Apr 10, 2023 | 01:27 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Perhaps the damper slipped
Old Apr 10, 2023 | 02:16 PM
sandymane's Avatar
sandymane
Just in case check firing order. If yours is correct, I suggest running diagnostic codes which may show you the problem without guessing.
1995 Ford F 150 Pickup 5.0 liter V-8 VIN "N"
Old Apr 10, 2023 | 03:27 PM
rla2005's Avatar
rla2005
1994 and up 5L engines use the 302HO/5.8L firing order (1-3-7-2-6-5-4-8)
Use this to verify the OP is using the correct firing order and the plug wires are routed to prevent crossfiring.
None of that would cause the motor to require substantial amount of base timing, I expect the outer ring of the balancer has spun or the OP is using the wrong reference marks.
Old Apr 10, 2023 | 03:33 PM
Prototypemech's Avatar
Prototypemech
Check your EGR valve for leakage.
Old Apr 10, 2023 | 03:36 PM
sandymane's Avatar
sandymane
Thanks Randy. Proving you can't always trust what you look up. I now see where the 5.0 and 302 changed in 1995. Sorry about the bogus info OP
Old Apr 10, 2023 | 04:04 PM
rla2005's Avatar
rla2005
Those pesky 5L nuances still trip me up from time to time.
Old Apr 11, 2023 | 04:21 AM
manicmechanic007's Avatar
manicmechanic007
It does not have a reman distributor in it right? (the roll pins shear on a regular basis)
I see no reference to disconnecting the spout wire to set the base time
Old Apr 11, 2023 | 04:25 AM
My4Fordtrucks
Last line in post #1
Old Apr 11, 2023 | 04:48 AM
manicmechanic007
I see now
A KOEO code test revealed?
Needs KOER test as well
Old Apr 11, 2023 | 07:12 AM
My4Fordtrucks
I see now
and fuel pressure test.
Rich Ruff
May 2, 2017 06:07 PM
Danodemano
Aug 24, 2013 05:49 PM
kyleag89
Mar 30, 2012 12:41 PM
rjbbrb8173
Nov 9, 2007 08:22 PM
morepower16
35
Sep 13, 2004 02:19 PM
