vacuum questions
Old Apr 10, 2023 | 11:35 AM
sddaltongang's Avatar
sddaltongang
vacuum questions
Is there a way to check if the vacuum hoses & or actuators on the dash of my '78 f250 are leaking/working?
Since I have not yet had the truck running, but have the dash all apart I wanted to see if there is any problems with this system before I put it all back in the dash.
I did check each actuator at the heater housing to see if they hold vacuum & each of these three seem to hold vacuum ok.
Next dumb question is: do I need a vacuum reservoir? I have had the 460 rebuilt in a local machine shop & had the entire from end clip off. There is a black gallon can which was under the drivers side front fender if I remember correctly.
Is that the vacuum reservoir? Thank you for your patience with my inane questions!
Old Apr 10, 2023 | 12:11 PM
aquanaut20's Avatar
aquanaut20
Yes that would be the reservoir,, you an use a smoke machine to check the validity of all the vacuum system, where there is smoke there is a leak..
erikkloss
Jan 20, 2017 04:00 PM
pecanguy
Aug 18, 2013 08:36 PM
'91 Silver Devil
Jun 10, 2006 11:18 PM
71LTD390
Jan 18, 2004 08:09 PM
