1995 F150 Front Leveling Question
Old Apr 6, 2023 | 07:57 PM
andy011's Avatar
andy011
I'm going to level the front of my 1995 F150 project truck I have been working on. 4x4 now with a 351 Engine. Was previously a 302. It has the dual shocks in the front, and appears to be original shocks and springs. I have decided on the MOOG CC824 springs to raise the front., unless someone can recommend something better. I see Jeff's Bronco Graveyard has a set that will raise 1.5" in the JBG name. Rough Country has a similar 1.5" leveling spring. I used the MOOG CC824 on my other 1995 F150 and they seemed to give me the lift I am looking for on this one.
Anyway, What I really want to know is what camber bushings I should order, as I know it will be needed. Also, what replacement shocks are recommended, or just leave the old ones on? I would love Bilstein 5100's, but they are not made for a more stock level like I am doing (Can only find for 4" lift.). I think I would have to go with 4600's. Bilsteins are expensive though.
Old Apr 6, 2023 | 08:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by andy011
I'm going to level the front of my 1995 F150 project truck I…. I have decided on the MOOG CC824 springs to raise the front., unless someone can recommend something better. I see Jeff's Bronco Graveyard has a set that will raise 1.5" in the JBG name. Rough Country has a similar 1.5" leveling spring. I used the MOOG CC824 on my other 1995 F150 and they seemed to give me the lift I am looking for on this one.
Anyway, What I really want to know is what camber bushings I should order, as I know it will be needed….
I don’t remember if I used 824 or 844 springs but in order to get it back in specs, I need to use 2” drop brackets for the pivot and radius arms.
It is impossible to answer your question about what eccentrics to install. What degree eccentrics are in the now? How much are the springs going to change your current settings?
Old Apr 7, 2023 | 07:04 AM
andy011's Avatar
andy011
No idea what is in there now. Whatever stock is I assume. Springs should raise 1.5" to 2" based on the description and my previous experience. Note that last time I did this on my other truck, I wasn't even purposefully intending to level anything. I was just replacing old springs and the CC824 was what the spring shop sold me. I remember that the alignment shop had to install new camber bushings after that, and the alignment and ride were great from that point on.
Old Apr 7, 2023 | 10:09 AM
torq'ta 5 8's Avatar
torq'ta 5 8
good reading-->Moog 844 Lift - Ford Truck Enthusiasts Forums
Old Apr 8, 2023 | 06:57 AM
andy011's Avatar
andy011
Originally Posted by torq'ta 5 8
Read through the thread...looks like either the 844 or the 824 will work...just depends on how stiff you want it, and how heavy your front is. I'm really not sure which to go with. I did read a few threads where people started off with the 844 and then later swapped to the 824 because the 844 was stiff. I know the 351 weighs more than the 302, but I don't think it is enough to make much of a difference for spring compression. As I read, the 844 was rated for use with the Diesel engines...which is a bit heavier.
Old Apr 8, 2023 | 07:10 AM
My4Fordtrucks
Whatever stock is I assume…. I was just replacing old springs and the CC824 was what the spring shop sold me.
I thought I posted this yesterday but apparently I did not.
I doubt every truck that rolled down the assembly line got exactly the same eccentric when it got aligned. I don’t know why the shop sold you that particular spring.
twisted
1978 - 1996 Big Bronco
Mar 10, 2007 10:21 PM
Psychobabble
Feb 6, 2007 04:26 PM
yup
Apr 27, 2004 09:25 PM
spencry25
Jul 17, 2003 11:03 AM
anollmann
Mar 11, 2003 04:25 AM
