Carb choke heater?
Old Apr 5, 2023 | 07:00 PM
johnr6's Avatar
johnr6
Carb choke heater?
I have a 390 with a 2barrel has elec choke found the fitting on the choke with nothing connected, looking online it shows choke heater with a plate on the manifold. I dont have that on my manifold? Can i plug that or connect somewhere else? Thanks
Old Apr 5, 2023 | 07:21 PM
440 sixpack's Avatar
440 sixpack
That was for the original thermal choke. if you have an electric choke it doesn't need anything except a 12V wire. so you can do whatever you want with the old tubes.
Old Apr 5, 2023 | 07:40 PM
LandAndStone's Avatar
LandAndStone
Desk Jockey
I think that choke is electric assist — 6V not 12V. Maybe bust out the voltmeter and check. If 6V then the heat riser is intended and can be refabbed using a Dorman kit. If 12V it’s getting plenty of power to open the choke and the heat riser not doing much more.
Old Apr 5, 2023 | 07:47 PM
Rubiranch's Avatar
Rubiranch
The power for the electric choke thermostat come off the stator connection on the back of the alternator.
faststang94
Apr 4, 2008 06:48 PM
Payperboy
May 3, 2007 09:58 PM
gsx
Jan 27, 2003 08:24 PM
73F100XLT
Dec 1, 2002 03:27 PM
