93 f150 rough starting.
Old Apr 3, 2023 | 09:31 PM
OBS4ever's Avatar
OBS4ever
In the cold my truck starts okay, but when the engine is warm or even in warm weather, it takes 2 to 3secomds to start. I just checked codes and found nothing wrong according to the computer. I am completely lost on where to look next. I am wondering what I need to look at and what is causing this problem.
Old Apr 3, 2023 | 10:30 PM
Prototypemech's Avatar
Prototypemech
I would start by checking the resistance of you engine coolant temp (ECT) sensor and your intake air temp (IAT) sensor. Check them when the engine is cold in the morning and then check them again after driving the truck for 15 minutes. You'll need a multimeter. Compare your resistance measurements to the ones on this chart.
If that's good, the next thing I'd do is unscrew your gas caps for a day. It's possible that you have a leaking injector, and as the temperature increases, evaporative pressure increases inside the fuel tank and forces fuel into you intake manifold through the leaking injector.
Old Apr 4, 2023 | 08:15 AM
OBS4ever's Avatar
OBS4ever
I have already changed the act and Ect sensors as they were bad.
Old Apr 4, 2023 | 08:30 AM
OBS4ever's Avatar
OBS4ever
I think the problem may be the fuel pressure regulator allows fuel to run back into the tank.
Old Apr 4, 2023 | 09:45 AM
Prototypemech
Check you new sensors to make sure they're behaving correctly. And then loosen you gas caps. Those checks cost you $0.
Dont *****-nilly replace your fuel pressure regulator until after you determine its bad. Put a fuel pressure gauge on your fuel rail and diagnose it properly. https://www.ford-trucks.com/forums/1...rd-trucks.html
Old Apr 6, 2023 | 10:36 AM
OBS4ever's Avatar
OBS4ever
How do you find a leaking injector.
1990-f250
Feb 28, 2017 07:10 PM
Mindy -
Apr 9, 2010 12:46 PM
