air bag lite flashing?
Old Nov 16, 2003 | 09:43 PM
catmech's Avatar
catmech
Lightbulb air bag lite flashing?
went out today and lite flashs any help here?
Old Nov 16, 2003 | 10:27 PM
Fordman4x4's Avatar
Fordman4x4
Is your Speedo or OD light acting weird at all? Sounds like it could be the speed sensor on the rearend...
Nelson
Old Nov 16, 2003 | 10:30 PM
catmech's Avatar
catmech
NO speedo correct.od works fine just flash on dash any thoughts on disconnect?
Old Nov 16, 2003 | 10:39 PM
Fordman4x4's Avatar
Fordman4x4
Well it still sounds like the speed sensor to me, just from the posts i've read on here before, but if you say the light is still flashing you could go down to Autozone or a similar parts stores and have them pull the codes for you. They do it for free, and it would tell you for sure.
Nelson
Old Nov 18, 2003 | 08:21 PM
BlackDually's Avatar
BlackDually
Mine came on because my light on the passenger on/off switch burnt out, cant replace just the light, have to buy the whole thing. Dont know if this is the same problem you are having, depends on what code the airbag light is flashing at you, then call your dealer and ask what the code means......
Old Nov 18, 2003 | 09:00 PM
Fordman4x4's Avatar
Fordman4x4
Oh crap...I just reread the your first post, I thought you said abs light. Sorry
Nelson
Old Nov 19, 2003 | 02:07 PM
catmech's Avatar
catmech
Question
this bag lite will flash out a code of 24 then lite stays on.any help here?
