SPOUT
Old Mar 28, 2023 | 10:36 AM
Ralphies54's Avatar
Ralphies54
Trailering
SPOUT
Some what new guy here with a question. What does the initials SPOUT stand for and what does it do and where is it on my 93 4.9 engine. I understand most if not all of the initial definitions as I read the posts but SPOUT I do not. Thanks Ralphie.
Old Mar 28, 2023 | 01:24 PM
Anonymous12's Avatar
Anonymous12
Don’t know where it is. Or what it stands for. But on my 302 people told me if the computers bad and it’ll start without it. And to remove it to set the engine timing. There’s other people that can tell you more than I can. That’s all I know about it.
Old Mar 28, 2023 | 02:12 PM
sswari's Avatar
sswari
It is on the driver's side, up by the ECU may be hanging loose, it is a small Gray dongle type thing.
The motor will start with or with out it plugged in.
It is used to be able to set the base timing which should always be at 10d before TDC with the SPOUT removed.
Here is a GOOGLE SEARCH for it.
Old Mar 28, 2023 | 02:29 PM
rla2005's Avatar
rla2005
SPOUT= Spark Output. It is the signal sent by the computer to control the timing. The SPOUT plug is a simple shorting bar to connect the computer to the Ignition Control Module (ICM). SPOUT plug out removes the computer SPOUT output which allows the ICM to trigger off the raw PIP signal from the distributor so you can set the base timing. With the SPOUT plug in the computer is controlling the ignition timing.
This is the ignition diagram for your 1993 model year truck.
Old Mar 29, 2023 | 12:15 AM
Scndsin's Avatar
Scndsin
Think pulling vac line off vacuum advance on a points distributor & locking out centrifugal advance at the same time...
Only electronically.
Old Mar 29, 2023 | 07:57 AM
Ralphies54's Avatar
Ralphies54
Trailering
Thanks to all,who answered me, who a thunk it SPark OUTput
FX4-350
Jan 16, 2014 07:59 PM
300-six
Nov 12, 2012 11:50 AM
97rangerguy
Apr 29, 2005 03:33 PM
bronco007
Mar 12, 2002 07:54 PM
craigz
Apr 5, 2001 10:02 PM
