Tough Guard Availability
Old Mar 27, 2023 | 12:29 PM
lawnspecialties's Avatar
lawnspecialties
For some reason, I'm thinking a little while ago that some things were holding back builds on some trucks ordered due to availability. I thought the Tough Guard bedliner was one of those things.
Is there any truth to this today? I'd rather get the Tough Guard from Ford but if it holds up production, I'll just go with a local company I've used before.
Old Mar 27, 2023 | 12:31 PM
CheeseheadFord's Avatar
CheeseheadFord
Skip the Ford bedliner and go Linex, much better quality and cheaper (assuming you go black). O yeah and LineX has a lifetime warranty as long as you own the truck.
Old Mar 27, 2023 | 12:40 PM
4wd6.7L's Avatar
4wd6.7L
Being that it's one extra step off of the assembly line there is a chance it could cause a delay. That could be a day, a few days. I haven't heard of it being a serious constraint at the moment. Yes there was a time when it held things up, and Ford even added the ability to delete it from certain packages that otherwise included the liner. I'm not aware of that being the case currently.
Getting it after delivery is not a bad option. The only thing you really miss out on is the "Ford" plaque on the bulkhead. Cost is comparable, sometimes cheaper from the aftermarket, and warranty is sometimes better aftermarket. Downside would be dropping the truck off and being without for about 3 hours.
Old Mar 27, 2023 | 12:44 PM
CheeseheadFord
Originally Posted by 4wd6.7L
.Downside would be dropping the truck off and being without for about 3 hours.
I'm sure adding the Ford bedliner adds more than 3 hours to your build though. And if you can't be without a truck a lot of dealers work with local liner companies and will have it done before you pick up your truck anyway. Or at least they did that for MY22, I don't see why that would change for MY23.
Old Mar 27, 2023 | 02:44 PM
lawnspecialties
I have decided to remove the Tough Guard from my order. I've already contacted the guys who installed all my previous bedliners and they're ready whenever I am.
boulderbronco
Aug 25, 2021 07:33 PM
BrianF250VA
Feb 8, 2017 11:05 AM
onebadgt
6.7L Power Stroke Diesel
18
May 26, 2016 05:21 AM
Gicknordon
24
Mar 27, 2015 01:02 PM
Aztrainer
2009 - 2014 F150
28
Jan 14, 2010 09:15 AM
