Weird Electrical Issue
Old Mar 23, 2023 | 03:25 PM
lukeaj's Avatar
lukeaj
3rd Gear
Have a weird electrical issue that I need some advice on what it could be. Whenever I try start the truck, I blow the 20amp maxi fuse #10 in the engine compartment fuse box. It is labeled as "Instrument panel fuses: 15,18, Starter relay coil". If I unplug the starter relay, it still blows. If I pull fuse 15 and 18 and turn over to start it won't blow. When I put in fuse 18 and have the start relay and 15 pulled, it will still blow. Now, if I have both fuses and starter relay connected and I just put the key to ignition on, I can manually trigger the starter relay and it starts and runs fine.
Looking for any ideas what could cause this.
Old Mar 23, 2023 | 04:05 PM
knottyrope's Avatar
knottyrope
think your starter relay coil is bad next to battery on pass side or maybe the wire to it is shorted to frame
Old Mar 23, 2023 | 04:47 PM
lukeaj's Avatar
lukeaj
3rd Gear
I thought that a first too, but if I pull only fuse 18 inside the instrument panel (which is a 10 amp fuse for Brake shift interlock, Speedometer, Selectable RPM control (Diesel), Speed control (Diesel)) it starts right up and doesn't blow the fuse. After the truck is started I can throw it right back in. Only moving the key to the start position with fuse 18 in blows the 20 amp in the engine compartment.
Old Mar 23, 2023 | 05:50 PM
lukeaj's Avatar
lukeaj
3rd Gear
Found it I think. My brake shift interlock is broke. Rather than getting stuck not being able to shift, I can shift without pressing the brake. For some reason it is blowing the engine compartment fuse rather than the instrument panel fuse... and only when going to start the car... just enough extra drain on the whole circuit? Going to try replacing it and see if that fixes the issue.
Old Mar 27, 2023 | 08:37 AM
knottyrope's Avatar
knottyrope
unlug fuel bowl heater, not sure if on same circut but has been known to short out and do similar
Daniel Calhoun
Jul 29, 2016 06:28 PM
muchocheko
Apr 20, 2011 10:40 PM
flyoil
1983 - 2012 Ranger & B-Series
Apr 11, 2011 06:05 AM
CopperEddie06
Aug 21, 2008 11:35 AM
f-4x4
Electrical Systems/Wiring
Dec 18, 2004 02:18 PM
