Oil Plug Torque
I finally got five minutes to myself and started putting my engine back together. It's been sitting for over a month since coming back from the maching shop. Ah well, we're all busy - ask any one of us.
To the point - I can't find the torque spec for the oil plug in any of my books or literature. Yes, I know, just torque that puppy down. It would be nice to know the recommended number, though, since it has a hard fiber washer behind it and they don't like to be squashed to smithereens. If anybody has a number I'd sure appreciate it. This is for the 7/8"-16 oil plug, not the 3/4"-24 plug used on some of the earlier engines or the 1/2"-20 used on later ones.
I know you won't care much for this answer but there is too much variance in the washer/gasket material for a precise answer.
Glad to hear you finally had a few minutes to work on your truck anyway.
I found out I can get a box of 100 hard fiber gaskets for about $6 or so. I'll follow your advice and test a few at different (resonably low) torque values to see what I can get away with and still have no oil leaks.
You're right Dewayne, I doubt it has to be very precise given the type of materials involved and the fact that there isn't any pressure on the seal.
Cheers!
I would guess I go about a quarter turn after it starts getting snug. Haven't had any problems with leaking.Actually, I went through this same problem when putting the oil lines back on the engine and filter. Rather than risk stripping the threads, I tightened them reasonable, filled everything up and made sure the ends of the lines were clean, then started it up and watched for a few minutes to see what leaked. It took maybe 20 minutes of monkeying around but in the end I had a leak-free system.
