flooding when warm
Old Nov 16, 2003 | 05:11 PM
aoldford's Avatar
aoldford
Question flooding when warm
My 1969 f-100, 360, 2bbl almost always floods when warmed up. It starts great when cold. Any general ideas?
Thanks, Joe
(p.s. Same truck with questionable vacuum advance)
Old Nov 18, 2003 | 01:15 AM
kermmydog's Avatar
kermmydog
Generally I would suggest to high float, or a float that is too heavy because of being gas soaked. Just a thought not knowing type of carb or model.
Old Nov 18, 2003 | 06:27 AM
LxMan1's Avatar
LxMan1
Is the carb getting real hot? It could be boiling the fuel. You might try lowering the float level just a little bit.
Jimmy
Old Nov 27, 2003 | 05:57 PM
aoldford's Avatar
aoldford
What does "high float" mean? Yes, the carb does get pretty hot. Maybe not enough to boil? I've been told in the past that a thicker spacer under the carb might help keep it cooler, but I,m not sure. I'll look at the float sometime. It,s an autolite 2100 2bbl.
Thanks for answering
Joe
