2011 - 2019 Explorer Discuss the 2011 to 2019 Explorer
2011 PTU replace with 2016+ PTU?
Old Mar 19, 2023 | 11:16 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
2011 Ford Fle . . . . errr . . . ummm . . . Explorer with 158,000 miles on it. The transfer case is making a lot of noise, so it's probably about to go bad like they do. It looks like the same model transfer case was an option all the way to 2019. It also looks like another version of this same case was offered from 2013 to 2019 with an oil cooler. The oil cooler appears to be a minor change to the passenger side cover of the existing case, cooling the case and therefore the oil with coolant passing through.
Side note: using 195+ degree coolant to cool this PTU tells me how hot that thing must get under there!
My question: Are the old (non oil-cooler) and new (with oil-cooler) versions of the transfer case interchangeable?
If so, I'd love to replace my failing 2011 factory unit with the 2016+ unit that has the oil cooler and the drain plug.
Thanks!
Old Mar 20, 2023 | 07:21 AM
projectSHO89's Avatar
projectSHO89
See https://www.explorerforum.com/forums.../#post-3987386 for info.
Old Mar 20, 2023 | 09:00 PM
CathedralCub
FTE Community Team
Originally Posted by projectSHO89
Thanks! Just what I needed!
I think I'll pre-install PTU coolant lines with elbows turning them around at the end, then replace the PTU.
Binkowski
Jun 7, 2016 07:23 PM
rungunner
Dec 15, 2007 12:43 AM
Jetfixr
Aug 28, 2006 08:53 AM
mr_soma23
Apr 18, 2004 05:15 PM
