What to replace
Old Mar 19, 2023 | 10:10 AM
jrm1's Avatar
jrm1
4th Gear
What to replace
2003 EXP 5.4 w/rear AC, 183k miles. Replacing the compressor due to failed clutch coil. It appears the compressor was replaced once before, as the replacement coil doesn’t fit. That would have been prior to my owning 100k miles ago. I’m not sure what other system parts would have been change. The system worked fine up until the coil failed, so no catastrophic failure.
I have the tools to do, but don’t do this professionally or that often. Besides the compressor, should I change any other components?
Old Mar 19, 2023 | 10:22 AM
RLXXI's Avatar
RLXXI
I would base my opinion on the condition of the orifice tube. It's essentially an inline filter and catches all debris if any and will give you a good indication of internal system integrity. If it's clean, simply replacing the compressor is likely the only thing needed so long as you can pull a solid 28-30" vacuum for at least an hour after you close the system.
If it has any debris at all, a full system flush and new accumulator will be needed and of course you won't want to reinstall the old orifice in any case, replace it.
Old Mar 19, 2023 | 01:26 PM
projectSHO89's Avatar
projectSHO89
Most aftermarket or replacement compressor warranties REQUIRE replacement of the orifice tube and accumulator anyway. Plan accordingly.
Old Mar 20, 2023 | 04:43 AM
jrm1's Avatar
jrm1
4th Gear
Thanks for the tips, much appreciated. This has expansion valves, front and back. Cost is minimal for the accumulator and valves, worth replacing.
snorindad
Jun 24, 2015 01:26 PM
hackdog
May 21, 2014 07:23 PM
stuart1031
Aug 16, 2009 12:15 AM
lippsenator
Jun 19, 2009 03:02 PM
msgntsu
Aug 6, 2007 08:18 PM
