uvch elec question
Old Mar 18, 2023 | 06:31 PM
kitz's Avatar
kitz
uvch elec question
i have a electric question see if someone can answer for me why would my valve cover injector plugs for the uvch have 4.46 volts on drivers side and 1.33 on pass side on center pin in the plugs this is a 97 f250 7.3l diesel with two plugs on each side my buzz test is showing p1294 so i checked center pins for power and glow plug pins for continuity this is what i got could the icm be bad thanks
Old Mar 18, 2023 | 10:55 PM
Pickledboater's Avatar
Pickledboater
https://www.ford-trucks.com/forums/1...ter-pin-2.html
Check this out. It has links to a lot of diagrams that might help ya.
Old Mar 20, 2023 | 08:09 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...load-test.html
i have a simple one you can use in link above
flavo
Nov 3, 2013 08:45 PM
robles4242
Sep 28, 2010 12:47 PM
kilroy99
Feb 26, 2008 07:40 AM
herman2001
Sep 18, 2006 07:04 PM
Ed the outdoorman
Sep 22, 2003 02:29 PM
